NFC PN7120 on the i.MX6Q
  1. INTRODUCTION
  2. REQUIREMENTS
  3. KERNEL DRIVER
  4. DEVICE NODE
  5. NFC LIBRARY
  6. TESTING NFC READER
  7. REFERENCES
1. INTRODUCTION
This document is a step by step guide of the AN11697 PN7120 Linux Software Stack Integration Guidelines application note that can be downloaded from http://www.nxp.com/documents/application_note/AN11697.pdf . It explains how to add the PN7120 driver and NFC libraries to a Linux OS running in the i.MX6Q.
2. REQUIREMENTS
3. KERNEL DRIVER
According to the AN11697.pdf we must follow the below steps:
  1. From the Linux source directory:
    $ cd drivers/misc
    $ git clone https://github.com/NXPNFCLinux/nxp-pn5xx.git
  2. Add the below line in the Makefile of the current directory
    obj-y += nxp-pn5xx/
  3. Include the driver config in the drivers/misc/Kconfig file
    source "drivers/misc/nxp-pn5xx/Kconfig"
  4. Export the environment variables
    $ source source /opt/poky/1.7/environment-setup-cortexa9hf-vfp-neon-poky-linux-gnueabi
    $ export ARCH=arm
    $ export CROSS_COMPILE=$TARGET_PREFIX
    $ make imx_v7_defconfig
  5. Using menuconfig include the driver as module (<M>).
  6. Compile the modules and install the .ko files into the target rootfs.
    $ make  modules
  7. You can send the .ko files with scp
    $ make  INSTALL_MOD_PATH=~/Desktop/modules modules_install
    $ cd ~/Desktop/modules
    $ sudo scp -r lib/modules/3.14.28+g91cf351/kernel root@<board_ip>:/lib/modules/3.14.28+g91cf351/
4. DEVICE NODE
The PN7120 interfaces with an MCU or MPU via I2C interface, therefore the device must be described into a i2c node. The signals used in the PN7120 are shown below:
As you can see besides power, ground and I2C lines, an IRQ and Reset pins are needed. These pins must be configured as GPIO and one must generate an interrupt to the iMX6Q.
The chosen connection is shown below:
To achieve the above configuration, the device tree must be changed. The changes consist on adding a device node in the corresponding I2C bus, describing the PN7120.
&i2c1 {
        clock-frequency = <100000>;
        pinctrl-names = "default";
        pinctrl-0 = <&pinctrl_i2c1>;
        status = "okay";
        pn547: pn547@28 {
                compatible = "nxp,pn547";
                reg = <0x28>;
                clock-frequency = <400000>;
                interrupt-parent = <&gpio6>;
                interrupt-gpios = <&gpio6 2 0>;
                enable-gpios = <&gpio5 22 0>;
The pinctrl_i2c1 phandle contains the I2C pins configuration. Make sure that the PADs connected to the PN7120 are not used in other device node.
&iomuxc {
        imx6q-udoo {
                pinctrl_i2c1: i2c1grp {
                        fsl,pins = <
                        MX6QDL_PAD_GPIO_5__I2C3_SCL             0x4001b8b1
                        MX6QDL_PAD_GPIO_6__I2C3_SDA             0x4001b8b1
After this you can generate the dtb file and send it with scp
make dtbs
sudo scp arch/arm/boot/dts/imx6q-udoo.dtb root@<board_ip>:/run/media/mmcblk0p1/imx6q-udoo.dtb
NOTE:
Attached you can find the complete dts and dtsi files used in this document.
5. NFC LIBRARY
To work with the PN7120 in Linux the libnfc-nci stack is needed. You can find more details in http://www.nxp.com/documents/application_note/AN11697.pdf​ . This sections explains how to cross-compile the libray and install the required files in the target (The below steps must be performed in the host).
  1. Get the library
    $  git clone https://github.com/NXPNFCLinux/linux_libnfc-nci.git
  2. Generate the configuration script
    $ ./bootstrap
  3. Mount the target rootfs to /mnt in the host.
    $ sudo mount /dev/sdX2 /mnt
  4. Generate the Makefile
    $ ./configure --host=arm-none-linux --prefix=/opt/poky/1.7/sysroots/x86_64-pokysdk-linux/usr --sysconfdir=/mnt/etc
  5. Build and install the source code
    $ make
    $ make install
  6. After a succesful bulding the libraries and a application demo are built in .libs directory. Copy the libaries to /usr/lib directory of the target and nfcDemoApp to /usr/sbin
    $ cd linux_libnfc-nci/.libs
    $ sudo cp * /mnt/usr/lib/
To test the application you have to follow the below steps on the target:
  1. Install the .ko file
    $ insmod /lib/modules/3.14.28+g91cf351/kernel/drivers/misc/nxp-pn5xx/pn5xx_i2c.ko
  2. Run the nfcDemoApp
    $  nfcDemoApp poll
    You should get a console output like the shown below when placing a NFC tag next to the NFC reader.
7. REFERENCES
Integrating NFC Controller library with KSDK
http://www.nxp.com/documents/user_manual/UM10878.pdf
ラベル(3)
コメント
Hi gusarambula, jamesbone​, CarlosCasillas​, jimmychan​,
Would you be nice enough to skim through the document and provide your feedback?
Alejandro
Look very good, alejandrolozano​! I just think you didn't attached the device tree files.
Thanks for the good document sharing.
Hi Alex, very good and well structured document.
I just recommend changing the second person sentences like "As you can see besides power" to non-personal like "As shown besides power".
Best regards!
I follow the document want try on our IMX6DL platform with PN544 (base 3.14.52_v1.1.0qa )
but I get the below error message!
insmod /lib/modules/3.14.52+g92a293a/kernel/drivers/misc/pn5x
pn54x_dev_init
pn54x_probe
pn54x 0-0028: CLKREQ GPIO <OPTIONAL> error getting from OF node
0-0028 supply nxp,pn54x-pvdd not found, using dummy regulator
0-0028 supply nxp,pn54x-vbat not found, using dummy regulator
0-0028 supply nxp,pn54x-pmuvcc not found, using dummy regulator
0-0028 supply nxp,pn54x-sevdd not found, using dummy regulator
pn54x_probe: request irq_gpio 159
pn54x_probe: request ven_gpio 5
pn54x_probe: request firm_gpio 163
pn54x_probe : requesting IRQ 319
root@imx6dltinto:~# nfcDemoApp poll
##                                       NFC demo                                      ##
##                                 Poll mode actpn54x_dev_open : 10,56
ivated                           pn54x_dev_ioctl, cmd=1074063617, arg=1
#######################pn544_enable power on
                              ... press enter to quit ...
pn54x_dev_ioctl, cmd=1074063617, arg=0
pn544_disable power off
pn54x_dev_read: i2c_master_recv returned -5
Have anyone can help me to fix this issues!
currently our hardware modify to split  VEN and PMUVCC setting
VEN with VBAT/PMUVCC connecttion, will always printing out "pn54x_dev_read: i2c_master_recv returned -5" string
current our PMUVCC/VBAT always keep supply
just control VEN pin
get new result, but still failed, pending on "pn544_enable power on" when run nfcDemoApp poll
##                                       NFC demo                                      ##
##                                 Poll mode actipn54x_dev_open : 10,56
########################pn544_enable power on
That error as you may assume it is related to the i2c communication. Please make sure that the PN7120 is connected as it should.
I recommend you either to check with a scope or a logic analizer if the i2c frame is correct.
Alejandro
Hi Alejandor,
      First, thank you for your reply!
I need describe something to let you know
In my case are connection to PN544, not PN7120
And  have been testing Linux NFC subsystem , default pn544 with I2C workable still entry initiator mode, can't response tag
So I guess I2C bus should be work well.
please see this https://community.freescale.com/thread/385569 and neard_pn544_dmesg_kunyi - Pastebin.com  to get more detail
BTW l'll double check I2C bus signal  on our hardware platform now
Hi Alejandor,
    Today I debug this, don't like I2C bus issues, Like PN544 chip not response,
this libnfc-nxp want get response, but never have response.
I to modify libnfc-nxp.conf to enable some debug message, I see the program want read  3byte response
when before send "20 00 01 01" to PN544,
I don't know "20 00 01 01" what's mean
but I guess the command not acceptable on PN544
##    pn54x_dev_open : 10,56
  NFC demo                       pn544_enable power on
##                                 Poll mode activated                                 ##
NxpHal:     Entering phNxpNciHal_init_monitor
NxpHal:     Returning with SUCCESS
NxpTml:     Opening port=/dev/pn544
NxpTml:     phTmlNfc_i2c_reset(), VEN level 1
NxpTml:     pn54x_dev_ioctl, cmd=1074063617, arg=0
phTmlNfc_i2c_reset(), VEN level 0pn544_disable power off
NxpTml:     pn54x_dev_ioctl, cmd=1074063617, arg=1
phTmlNfc_i2c_reset(), VEN level 1pn544_enable power on
NxpTml:     i2c->:00000000: 20 00 01 01
PN54X - Tml Reader Thread Started................
NxpTml:     PN54X - Tml Writer Thread Started................
NxpTml:     PN54X - Tml Writer Thread Running................
NxpTml:     NxpHal:     PN54X - Write requested.....
NxpTml:     PN54X - Invoking I2C Write.....
thread started
NxpTml:     PN54X - Read requested.....
NxpTml:     PN54X - Invoking I2C Read.....
NxpTml:     PN54X - I2C Write successful.....
NxpTml:     PN54X - Posting Fresh Write message.....
NxpHal:     write successful status = 0x0
NxpHal:     Response timer started
NxpHal:     Waiting after ext cmd sent
NxpHal:     pn54x_dev_ioctl, cmd=1074063617, arg=1
hal_extns_write_rsp_timeout_cb - pn544_enable power on
write timeout!!!
NxpHal:     Response timer stopped
NxpHal:     Callback Status is failed!! Timer Expired!! Couldn't read it! 0xff
NxpHal:     NCI_CORE_RESET: Failed
NxpHal:     Power Cycle
NxpTml:     _i2c_read() [hdr] errno : 5
Nxppn54x_dev_read: i2c_master_recv returned -5
Tml:     PN54X - Error in I2C Reapn54x_dev_read: i2c_master_recv returned -5
d.....
NxpTml:     PN54X - Reapn54x_dev_read: i2c_master_recv returned -5
d requested.....
NxpTml:     Ppn54x_dev_read: i2c_master_recv returned -5
NxpTml:     _i2c_read() [hdr] errpn54x_dev_read: i2c_master_recv returned -5
no : 5
NxpTml:     PN54X - Errorpn54x_dev_read: i2c_master_recv returned -5
in I2C Read.....
NxpTml:     pn54x_dev_read: i2c_master_recv returned -5
Nxpn54x_dev_read: i2c_master_recv returned -5
Hi Alejandor,
     Okay, I know why not work on  NXP PN544 now!
     Because PN7120 use NFC Forum/NCI interface base,
     but PN544 to use ETSI/HCI interface,
     either use I2C but command/protocol format totally difference.
For information on using the PN7150 NFC Demoboard you may refer to the following document, which is related to this one.
PN7150 NFC on the i.MX6SX
Thank you for your informations. if possible would you tell me how to get PN544 documents and firmware/FRI-SDK.
because my project will go into MP stage,
from AOSP source code find out some configuration for PN544 and neard & neardal can workable on my project
Driver is accessing regulator for NFC from the device tree but here those regulator names are not available in the device tree code . Can anybody help me to add the regulator in dtsi files. I am using SODIMM iMx6Dualite board with Linux 3.10.53 Kernel.
For enabling (pn544_enable) - > (dev->pvdd_reg, dev->vbat_reg,dev->pmuvcc_reg, dev->sevdd_reg). where these regulators are assigned in device tree. Is it really required to enable the NFC.
Dooty.
Hi Dooty,
    I guess you should use  AOSP driver code, due to the driver code use your enabled sequence on PN54x
    but just need have an enabled pin, it is dependence hardware design
    and the article just for PN71xx not for PN54x
    if want add others regulators control pin, check "enable-gpio" in driver code then to add others into same place
Hi KunYi Chen,
Thank your for the response. What is AOSP driver. I agree the points that regulator enable required depends on the hardware design.
Here you are saying about this article is for PN71xx and not for PN54x. But when I check out the driver code from git repository, it is downloading the driver of nxp-pn5xx and the application is nfcDemoApp (linux_libnfc-nci). Then why it is been added the driver code name pn544 for the PN71xx module. It is little bit confusing.
Here I am using the exact nfc module part number is nxp PN7120A0EV and it is connected via i2c interface on SODIMM iMx6Dualite processor.
I am following this document :- http://www.nxp.com/documents/application_note/AN11697.pdf
So please suggest me whether I can go ahead and proceed the above git repository for the Kernel device driver and nfcDemoApp application  or do you any other suggestion to support different source code (Kernel and application) for the respective NFC module (PN7120A0EV).
Thank you in Advance.
Dooty.
Okay, I see you use NXP PN7120A0EV, so you need check your hardware write first
The article use GPIO5_IO22 to enabled all regulator
you need to check your hardware how to wiring connecting the to  modify you driver and device tree file
AOSP: Android Open Source Project
Hi KunYi Chen,
Thank your for the response. Please can youreply me apart from the Hardware desgin, regualator and GPIO pins.
I need to know which Linux driver and application can be used my nfc module. I am working in Linux.
Dooty.
I compiled the linux_linnfc-nci library following the guide. When I try run nfcDemoApp I received the following error
nfcDemoApp: error while loading shared libraries: /usr/lib/libnfc_nci_linux-1.so: internal error
%3CLINGO-SUB%20id%3D%22lingo-sub-1106671%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Ei.MX6Q%E4%B8%8A%E3%81%AENFCPN7120%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1106671%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3COL%3E%3CLI%3E%3CSTRONG%3E%E3%81%AF%E3%81%98%E3%82%81%E3%81%AB%3C%2FSTRONG%3E%3C%2FLI%3E%3CLI%3E%3CSTRONG%3E%E8%A6%81%E4%BB%B6%3C%2FSTRONG%3E%3C%2FLI%3E%3CLI%3E%3CSTRONG%3E%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%20%3C%2FSTRONG%3E%3C%2FLI%3E%3CLI%3E%3CSTRONG%3E%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%8E%E3%83%BC%E3%83%89%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FLI%3E%3CLI%3E%3CSTRONG%3ENFC%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%3C%2FSTRONG%3E%3C%2FLI%3E%3CLI%3E%3CSTRONG%3ENFC%E3%83%AA%E3%83%BC%E3%83%80%E3%83%BC%E3%81%AE%E3%83%86%E3%82%B9%E3%83%88%3C%2FSTRONG%3E%3C%2FLI%3E%3CLI%3E%3CSTRONG%3E%E5%8F%82%E8%80%83%E6%83%85%E5%A0%B1%3C%2FSTRONG%3E%3C%2FLI%3E%3C%2FOL%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E1.%20%E3%82%A4%E3%83%B3%E3%83%88%E3%83%AD%E3%83%80%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23303030%3B%22%3E%E3%81%93%E3%81%AE%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%AF%E3%80%81%3CA%20href%3D%22http%3A%2F%2Fwww.nxp.com%2Fdocuments%2Fapplication_note%2FAN11697.pdf%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20title%3D%22http%3A%2F%2Fwww.nxp.com%2Fdocuments%2Fapplication_note%2FAN11697.pdf%22%20target%3D%22_blank%22%3E%20http%3A%2F%2Fwww.nxp.com%2Fdocuments%2Fapplication_note%2FAN11697.pdf%3C%2FA%3E%20%E3%81%8B%E3%82%89%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%A7%E3%81%8D%E3%82%8B%20AN11697%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23303030%3B%22%3E%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23303030%3B%22%3E%3CEM%3E%20PN7120%20Linux%20Software%20Stack%20Integration%20Guidelines%3C%2FEM%3E%3C%2FSPAN%3E%20%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%20%E3%83%8E%E3%83%BC%E3%83%88%E3%81%AE%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%20%E3%83%90%E3%82%A4%20%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%20%E3%82%AC%E3%82%A4%E3%83%89%E3%81%A7%E3%81%99%E3%80%82PN7120%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%A8NFC%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E3%82%92i.MX6Q%E3%81%A7%E5%8B%95%E4%BD%9C%E3%81%99%E3%82%8BLinux%20OS%E3%81%AB%E8%BF%BD%E5%8A%A0%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E8%AA%AC%E6%98%8E%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E2.%20%E5%BF%9C%E5%8B%9F%E8%B3%87%E6%A0%BC%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%E3%81%93%E3%81%AE%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%A7%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AF%E3%80%81%E3%83%94%E3%83%B3%E3%81%AB%E7%B0%A1%E5%8D%98%E3%81%AB%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81Udoo%E3%83%9C%E3%83%BC%E3%83%89%E3%81%A7%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E8%A9%B3%E7%B4%B0%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%3CA%20href%3D%22http%3A%2F%2Fwww.udoo.org%2F%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20title%3D%22http%3A%2F%2Fwww.udoo.org%2F%22%20target%3D%22_blank%22%3EAndroid%E3%81%8A%E3%82%88%E3%81%B3Linux%E7%94%A8%E3%81%AEUltimate%20Single%20Board%20Mini%20PC%20-%20UDOO%3C%2FA%3E%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FLI%3E%3CLI%3E%E4%BF%AE%E6%AD%A3%E3%81%95%E3%82%8C%E3%81%9FFSL%20L3.14.28BSP%E3%80%82%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E5%A4%89%E6%9B%B4%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-329664%22%20target%3D%22_blank%22%3EUdoo%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E5%9F%BA%E6%9C%AC%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%84%E3%83%AA%E3%83%BC%20%3C%2FA%3E%E3%81%A8%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-328200%22%20target%3D%22_blank%22%3EU-Boot%E7%A7%BB%E8%A1%8C%E4%BE%8B%3C%2FA%3E%20%E3%81%AE2%E3%81%A4%E3%81%AE%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%AB%E8%A8%98%E8%BC%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%3CLI%3E%E5%89%8D%E3%81%AE%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%9F%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%81%99%E3%81%A7%E3%81%AB%E5%8B%95%E4%BD%9C%E3%81%99%E3%82%8Byocto%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%A8%E3%83%84%E3%83%BC%E3%83%AB%E3%83%81%E3%82%A7%E3%83%BC%E3%83%B3(meta-toolchain)%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%81%9D%E3%81%86%E3%81%A7%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E6%9C%80%E5%88%9D%E3%81%AB%E3%81%93%E3%81%AE%E7%B4%A0%E6%99%B4%E3%82%89%E3%81%97%E3%81%84%E3%83%88%E3%83%AC%E3%83%BC%E3%83%8B%E3%83%B3%E3%82%B0%E3%81%AB%E5%BE%93%E3%81%86%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-94849%22%20target%3D%22_blank%22%3EYocto%E3%83%88%E3%83%AC%E3%83%BC%E3%83%8B%E3%83%B3%E3%82%B0%20-%20HOME%3C%2FA%3E%20%E3%80%82%3C%2FLI%3E%3CLI%3EOM5577%2FPN7120S%E3%83%87%E3%83%A2%E3%82%AD%E3%83%83%E3%83%88%E3%81%A7%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E6%8E%B2%E7%A4%BA%E6%9D%BF%E3%81%AE%E8%A9%B3%E7%B4%B0%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%3CA%20href%3D%22http%3A%2F%2Fwww.nxp.com%2Fdocuments%2Fuser_manual%2FUM10878.pdf%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20title%3D%22http%3A%2F%2Fwww.nxp.com%2Fdocuments%2Fuser_manual%2FUM10878.pdf%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fwww.nxp.com%2Fdocuments%2Fuser_manual%2FUM10878.pdf%3C%2FA%3E%20%E3%82%92%E3%81%94%E8%A6%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E3.%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EAN11697.pdf%E3%81%AB%E3%82%88%E3%82%8B%E3%81%A8%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AE%E6%89%8B%E9%A0%86%E3%81%AB%E5%BE%93%E3%81%86%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3COL%3E%3CLI%3ELinux%20%E3%82%BD%E3%83%BC%E3%82%B9%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%8B%E3%82%89%3A%3CBR%20%2F%3E%3CBR%20%2F%3E%3CPRE%20__default_attr%3D%22c%2B%2B%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_macro_code%20_jivemacro_uid_14545198788479338%20jive_text_macro%22%20data-renderedposition%3D%22677.2000122070312_48_1193_33%22%20jivemacro_uid%3D%22_14545198788479338%22%3E%24%20cd%20drivers%2Fmisc%0A%3CSPAN%3E%24%20git%20clone%20%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22https%3A%2F%2Fgithub.com%2FNXPNFCLinux%2Fnxp-pn5xx.git%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fgithub.com%2FNXPNFCLinux%2Fnxp-pn5xx.git%3C%2FA%3E%3C%2FPRE%3E%3C%2FLI%3E%3CLI%3E%E7%8F%BE%E5%9C%A8%E3%81%AE%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%AEMakefile%E3%81%AB%E4%BB%A5%E4%B8%8B%E3%81%AE%E8%A1%8C%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3E%3CBR%20%2F%3E%3CPRE%20__default_attr%3D%22c%2B%2B%22%20__jive_macro_name%3D%22code%22%20class%3D%22_jivemacro_uid_1454519872968205%20jive_macro_code%20jive_text_macro%22%20data-renderedposition%3D%22755.2333374023438_48_1193_16%22%20jivemacro_uid%3D%22_1454519872968205%22%3Eobj-y%20%2B%3D%20nxp-pn5xx%2F%3C%2FPRE%3E%3C%2FLI%3E%3CLI%3E%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E6%A7%8B%E6%88%90%E3%82%92drivers%2Fmisc%2FKconfig%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AB%E5%90%AB%E3%82%81%E3%81%BE%E3%81%99%3CBR%20%2F%3E%3CBR%20%2F%3E%3CPRE%20__default_attr%3D%22c%2B%2B%22%20__jive_macro_name%3D%22code%22%20class%3D%22_jivemacro_uid_14545198665565168%20jive_macro_code%20jive_text_macro%22%20data-renderedposition%3D%22837.0333251953125_48_1193_16%22%20jivemacro_uid%3D%22_14545198665565168%22%3E%E3%82%BD%E3%83%BC%E3%82%B9%3A%20%22drivers%2Fmisc%2Fnxp-pn5xx%2FKconfig%22%3C%2FPRE%3E%3C%2FLI%3E%3CLI%3E%E7%92%B0%E5%A2%83%E5%A4%89%E6%95%B0%E3%81%AE%E3%82%A8%E3%82%AF%E3%82%B9%E3%83%9D%E3%83%BC%E3%83%88%3CBR%20%2F%3E%3CBR%20%2F%3E%3CPRE%20__default_attr%3D%22c%2B%2B%22%20__jive_macro_name%3D%22code%22%20class%3D%22_jivemacro_uid_145451985709641%20jive_macro_code%20jive_text_macro%22%20data-renderedposition%3D%22918.8333129882812_48_1193_64%22%20jivemacro_uid%3D%22_145451985709641%22%3E%24%20%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%BD%E3%83%BC%E3%82%B9%20%2Fopt%2Fpoky%2F1.7%2Fenvironment-setup-cortexa9hf-vfp-neon-poky-linux-gnueabi%24%20export%20ARCH%3Darm%0A%24%20export%20CROSS_COMPILE%3D%24TARGET_PREFIX%0A%24%E3%81%AFimx_v7_defconfig%E3%82%92%E4%BD%9C%E3%82%8B%3C%2FPRE%3E%3C%2FLI%3E%3CLI%3Emenuconfig%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%82%92%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%20(%3CM%3E)%20%E3%81%A8%E3%81%97%E3%81%A6%E5%90%AB%E3%82%81%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_7.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_7.png%22%20style%3D%22width%3A%20367px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F52613i76E0BF58E20468E6%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_7.png%22%20alt%3D%22pastedImage_7.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FM%3E%3C%2FLI%3E%3CLI%3E%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%82%92%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%97%E3%80%81.ko%20%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%81%AE%20rootfs%20%E3%81%AB%E6%A0%BC%E7%B4%8D%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3CPRE%20__default_attr%3D%22c%2B%2B%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_macro_code%20jive_text_macro%20_jivemacro_uid_14545198501123104%22%20data-renderedposition%3D%221240.433349609375_48_1193_16%22%20jivemacro_uid%3D%22_14545198501123104%22%3E%24%20make%26nbsp%3B%20modules%3C%2FPRE%3E%3C%2FLI%3E%3CLI%3E.ko%20%E3%82%92%E9%80%81%E4%BF%A1%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99SCP%E3%82%92%E5%90%AB%E3%82%80%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%20%3CBR%20%2F%3E%3CPRE%20__default_attr%3D%22c%2B%2B%22%20__jive_macro_name%3D%22code%22%20class%3D%22_jivemacro_uid_14545198403521622%20jive_macro_code%20jive_text_macro%22%20data-renderedposition%3D%221301.2333984375_48_1193_48%22%20jivemacro_uid%3D%22_14545198403521622%22%3E%24%20make%26nbsp%3B%20INSTALL_MOD_PATH%3D~%2FDesktop%2Fmodules%20modules_install%0A%24%20cd%20~%2FDesktop%2Fmodules%0A%24%20sudo%20scp%20-r%20lib%2Fmodules%2F3.14.28%2Bg91cf351%2Fkernel%20root%40%3CBOARD_IP%3E%3A%2Flib%2Fmodules%2F3.14.28%2Bg91cf351%2F%3C%2FBOARD_IP%3E%3C%2FPRE%3E%3C%2FLI%3E%3C%2FOL%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E4.%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%8E%E3%83%BC%E3%83%89%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EPN7120%E3%81%AF%E3%80%81I2C%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%82%92%E4%BB%8B%E3%81%97%E3%81%A6MCU%E3%81%BE%E3%81%9F%E3%81%AFMPU%E3%81%A8%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AFi2c%E3%83%8E%E3%83%BC%E3%83%89%E3%81%AB%E8%A8%98%E8%BF%B0%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82PN7120%E3%81%A7%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%82%8B%E4%BF%A1%E5%8F%B7%E3%82%92%E4%BB%A5%E4%B8%8B%E3%81%AB%E7%A4%BA%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20center%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_7.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_7.png%22%20style%3D%22width%3A%20575px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F35854iC58183CDB6D28E10%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_7.png%22%20alt%3D%22pastedImage_7.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20left%3B%22%3E%3C%2FP%3E%3CP%3E%E3%81%94%E8%A6%A7%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%80%81%E9%9B%BB%E6%BA%90%E3%80%81%E3%82%B0%E3%83%A9%E3%83%B3%E3%83%89%E3%80%81I2C%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%AE%E3%81%BB%E3%81%8B%E3%81%AB%E3%80%81IRQ%E3%83%94%E3%83%B3%E3%81%A8%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%83%94%E3%83%B3%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E3%83%94%E3%83%B3%E3%81%AFGPIO%E3%81%A8%E3%81%97%E3%81%A6%E6%A7%8B%E6%88%90%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%80%81iMX6Q%E3%81%B8%E3%81%AE%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%82%92%E7%94%9F%E6%88%90%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E9%81%B8%E6%8A%9E%E3%81%97%E3%81%9F%E6%8E%A5%E7%B6%9A%E3%82%92%E4%BB%A5%E4%B8%8B%E3%81%AB%E7%A4%BA%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_0.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_0.png%22%20style%3D%22width%3A%20808px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F52565i4899512A7EBD7AD0%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_0.png%22%20alt%3D%22pastedImage_0.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%B8%8A%E8%A8%98%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%82%92%E5%AE%9F%E7%8F%BE%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%84%E3%83%AA%E3%83%BC%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E5%A4%89%E6%9B%B4%E3%81%AF%E3%80%81PN7120%E3%82%92%E8%AA%AC%E6%98%8E%E3%81%99%E3%82%8B%E3%80%81%E5%AF%BE%E5%BF%9C%E3%81%99%E3%82%8BI2C%E3%83%90%E3%82%B9%E3%81%AB%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%8E%E3%83%BC%E3%83%89%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E6%A7%8B%E6%88%90%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22c%2B%2B%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_macro_code%20_jivemacro_uid_14545198276365424%20jive_text_macro%22%20data-renderedposition%3D%222145.033447265625_8_1233_272%22%20jivemacro_uid%3D%22_14545198276365424%22%3E%3CP%3E%26amp%3Bi2c1%20%7B%3C%2FP%3E%3CP%3E%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E5%91%A8%E6%B3%A2%E6%95%B0%20%3D%20%26lt%3B100000%26gt%3B%3B%3C%2FP%3E%3CP%3Epinctrl-names%20%3D%20%22%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%22%3B%3C%2FP%3E%3CP%3E%E3%83%94%E3%83%B3ctrl-0%20%3D%20%26lt%3B%26amp%3Bpinctrl_i2c1%26gt%3B%3B%3C%2FP%3E%3CP%3Estatus%20%3D%20%22%E3%82%AA%E3%83%BC%E3%82%B1%E3%83%BC%22%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20pn547%3A%20pn547%4028%20%7B%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20compatible%20%3D%20%22nxp%2Cpn547%22%3B%3C%2FP%3E%3CP%3Ereg%20%3D%20%26lt%3B0x28%26gt%3B%3B%3C%2FP%3E%3CP%3E%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E5%91%A8%E6%B3%A2%E6%95%B0%20%3D%20%26lt%3B400000%26gt%3B%3B%3C%2FP%3E%3CP%3E%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E8%A6%AA%20%3D%20%26lt%3B%26amp%3Bgpio6%26gt%3B%3B%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20interrupt-gpios%20%3D%20%26lt%3B%26amp%3Bgpio6%202%200%26gt%3B%3B%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20enable-gpios%20%3D%20%26lt%3B%26amp%3Bgpio5%2022%200%26gt%3B%3B%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7D%3B%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%7D%3B%3C%2FP%3E%3C%2FPRE%3E%3CP%3Epinctrl_i2c1%20phandle%20%E3%81%AB%E3%81%AF%E3%80%81I2C%20%E3%83%94%E3%83%B3%E6%A7%8B%E6%88%90%E3%81%8C%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82PN7120%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8BPAD%E3%81%8C%E4%BB%96%E3%81%AE%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%8E%E3%83%BC%E3%83%89%E3%81%A7%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22c%2B%2B%22%20__jive_macro_name%3D%22code%22%20class%3D%22_jivemacro_uid_14545198179462552%20jive_macro_code%20jive_text_macro%22%20data-renderedposition%3D%222480.033447265625_8_1233_176%22%20jivemacro_uid%3D%22_14545198179462552%22%3E%3CP%3E%26amp%3Biomuxc%20%7B%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20imx6q-udoo%20%7B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20...%3C%2FP%3E%3CP%3Epinctrl_i2c1%3A%20i2c1grp%20%7B%3C%2FP%3E%3CP%3EFSL%E3%80%81%E3%83%94%E3%83%B3%20%3D%20%26lt%3B%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20MX6QDL_PAD_GPIO_5__I2C3_SCL%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200x4001b8b1%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20MX6QDL_PAD_GPIO_6__I2C3_SDA%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%200x4001b8b1%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%26gt%3B%3B%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7D%3B%3C%2FP%3E%3CP%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7D%3B%3C%2FP%3E%3CP%3E%7D%3B%3C%2FP%3E%3C%2FPRE%3E%3CP%3E%E3%81%93%E3%81%AE%E5%BE%8C%E3%80%81dtb%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E7%94%9F%E6%88%90%E3%81%97%E3%80%81scp%E3%81%A7%E9%80%81%E4%BF%A1%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CPRE%20__default_attr%3D%22c%2B%2B%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_macro_code%20_jivemacro_uid_14545198084262005%20jive_text_macro%22%20data-renderedposition%3D%222698.033447265625_8_1233_32%22%20jivemacro_uid%3D%22_14545198084262005%22%3E%3CP%3Emake%20dtbs%3C%2FP%3E%3CP%3Esudo%20scp%20arch%2Farm%2Fboot%2Fdts%2Fimx6q-udoo.dtb%20root%40%3CBOARD_IP%3E%3A%2Frun%2Fmedia%2Fmmcblk0p1%2Fimx6q-udoo.dtb%3C%2FBOARD_IP%3E%3C%2FP%3E%3C%2FPRE%3E%3CP%20style%3D%22text-align%3A%20center%3B%22%3E%E6%B3%A8%EF%BC%9A%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20center%3B%22%3E%E3%81%93%E3%81%AE%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%A7%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E5%AE%8C%E5%85%A8%E3%81%AA%20dts%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%A8%20dtsi%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E6%B7%BB%E4%BB%98%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20center%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20left%3B%22%3E%3CSTRONG%3E5.NFC%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%20%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20left%3B%22%3E%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20left%3B%22%3ELinux%E3%81%A7PN7120%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81libnfc-nci%E3%82%B9%E3%82%BF%E3%83%83%E3%82%AF%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%E3%80%82%E8%A9%B3%E7%B4%B0%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%20%3CA%20href%3D%22http%3A%2F%2Fwww.nxp.com%2Fdocuments%2Fapplication_note%2FAN11697.pdf%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20title%3D%22http%3A%2F%2Fwww.nxp.com%2Fdocuments%2Fapplication_note%2FAN11697.pdf%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fwww.nxp.com%2Fdocuments%2Fapplication_note%2FAN11697.pdf%3C%2FA%3E%20%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%81%93%E3%81%AE%E3%82%BB%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%A7%E3%81%AF%E3%80%81libray%20%E3%82%92%E3%82%AF%E3%83%AD%E3%82%B9%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%97%E3%80%81%E5%BF%85%E8%A6%81%E3%81%AA%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%81%AB%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E8%AA%AC%E6%98%8E%E3%81%97%E3%81%BE%E3%81%99%20(%E4%BB%A5%E4%B8%8B%E3%81%AE%E6%89%8B%E9%A0%86%E3%81%AF%E3%83%9B%E3%82%B9%E3%83%88%E3%81%A7%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99)%E3%80%82%3C%2FP%3E%3CP%20style%3D%22text-align%3A%20left%3B%22%3E%3C%2FP%3E%3COL%3E%3CLI%3E%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E3%82%92%E5%85%A5%E6%89%8B%E3%81%99%E3%82%8B%3CBR%20%2F%3E%3CPRE%20__default_attr%3D%22c%2B%2B%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_macro_code%20_jivemacro_uid_14545197939234019%20jive_text_macro%22%20data-renderedposition%3D%222921.833251953125_48_1193_17%22%20jivemacro_uid%3D%22_14545197939234019%22%3E%3CSPAN%3E%24%20git%20clone%20%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-external-small%22%20href%3D%22https%3A%2F%2Fgithub.com%2FNXPNFCLinux%2Flinux_libnfc-nci.git%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fgithub.com%2FNXPNFCLinux%2Flinux_libnfc-nci.git%3C%2FA%3E%3C%2FPRE%3E%3C%2FLI%3E%3CLI%3E%E6%A7%8B%E6%88%90%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%E3%81%AE%E7%94%9F%E6%88%90%3CBR%20%2F%3E%3CPRE%20__default_attr%3D%22c%2B%2B%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_macro_code%20jive_text_macro%20_jivemacro_uid_14545197845986652%22%20data-renderedposition%3D%222962.86669921875_48_1193_16%22%20jivemacro_uid%3D%22_14545197845986652%22%3E%24%20.%2Fbootstrap%3C%2FPRE%3E%3C%2FLI%3E%3CLI%3E%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%81%AE%20rootfs%20%E3%82%92%E3%83%9B%E3%82%B9%E3%83%88%E3%81%AE%20%2Fmnt%20%E3%81%AB%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CPRE%20__default_attr%3D%22c%2B%2B%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_macro_code%20_jivemacro_uid_14545197777792445%20jive_text_macro%22%20data-renderedposition%3D%223002.666748046875_48_1193_16%22%20jivemacro_uid%3D%22_14545197777792445%22%3E%24%20sudo%20mount%20%2Fdev%2FsdX2%20%2Fmnt%3C%2FPRE%3E%3C%2FLI%3E%3CLI%3E%E3%83%A1%E3%82%A4%E3%82%AF%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E7%94%9F%E6%88%90%E3%81%99%E3%82%8B%3CBR%20%2F%3E%3CPRE%20__default_attr%3D%22c%2B%2B%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_macro_code%20_jivemacro_uid_14545197693422932%20jive_text_macro%22%20data-renderedposition%3D%223042.466552734375_48_1193_16%22%20jivemacro_uid%3D%22_14545197693422932%22%3E%24%20.%2Fconfigure--host%3Darm-none-linux%20--prefix%3D%2Fopt%2Fpoky%2F1.7%2Fsysroots%2Fx86_64-pokysdk-linux%2Fusr%20--sysconfdir%3D%2Fmnt%2Fetc%3C%2FPRE%3E%3C%2FLI%3E%3CLI%3E%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%97%E3%81%A6%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%99%E3%82%8B%3CBR%20%2F%3E%3CPRE%20__default_attr%3D%22c%2B%2B%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_macro_code%20_jivemacro_uid_14545197607386426%20jive_text_macro%22%20data-renderedposition%3D%223082.2666015625_48_1193_32%22%20jivemacro_uid%3D%22_14545197607386426%22%3E%24%E4%BD%9C%E3%82%8B%0A%24%20make%20install%3C%2FPRE%3E%3C%2FLI%3E%3CLI%3E%E3%83%93%E3%83%AB%E3%83%89%E3%81%8C%E6%88%90%E5%8A%9F%E3%81%97%E3%81%9F%E5%BE%8C%E3%80%81%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E3%81%A8%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%83%87%E3%83%A2%E3%81%AF.libs%E3%81%A7%E3%83%93%E3%83%AB%E3%83%89%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%80%82%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E3%82%92%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%81%AE%20%2Fusr%2Flib%20%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%AB%E3%82%B3%E3%83%94%E3%83%BC%E3%81%97%E3%80%81nfcDemoApp%20%E3%82%92%20%2Fusr%2Fsbin%20%E3%81%AB%E3%82%B3%E3%83%94%E3%83%BC%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3E%3CPRE%20__default_attr%3D%22c%2B%2B%22%20__jive_macro_name%3D%22code%22%20class%3D%22jive_macro_code%20jive_text_macro%20_jivemacro_uid_1454519754415114%22%20data-renderedposition%3D%223138.066650390625_48_1193_32%22%20jivemacro_uid%3D%22_1454519754415114%22%3E%24%20cd%20linux_libnfc-nci%2F.libs%0A%24%20sudo%20cp%20*%20%2Fmnt%2Fusr%2Flib%2F%3C%2FPRE%3E%3C%2FLI%3E%3C%2FOL%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E6.%20NFC%E3%83%AA%E3%83%BC%E3%83%80%E3%83%BC%E3%81%AE%E3%83%86%E3%82%B9%E3%83%88%20%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E3%83%86%E3%82%B9%E3%83%88%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%81%A7%E6%AC%A1%E3%81%AE%E6%89%8B%E9%A0%86%E3%81%AB%E5%BE%93%E3%81%86%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3COL%3E%3CLI%3E.ko%20%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%97%E3%81%BE%E3%81%99%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%3CBR%20%2F%3E%3CPRE%20__default_attr%3D%22c%2B%2B%22%20__jive_macro_name%3D%22code%22%20class%3D%22_jivemacro_uid_1454519743091539%20jive_macro_code%20jive_text_macro%22%20data-renderedposition%3D%223301.666748046875_48_1193_16%22%20jivemacro_uid%3D%22_1454519743091539%22%3E%24%20insmod%20%2Flib%2Fmodules%2F3.14.28%2Bg91cf351%2Fkernel%2Fdrivers%2Fmisc%2Fnxp-pn5xx%2Fpn5xx_i2c.ko%3C%2FPRE%3E%3C%2FLI%3E%3CLI%3EnfcDemoApp%20%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%3CBR%20%2F%3E%3CPRE%20__default_attr%3D%22c%2B%2B%22%20__jive_macro_name%3D%22code%22%20class%3D%22_jivemacro_uid_14545197350794854%20jive_macro_code%20jive_text_macro%22%20data-renderedposition%3D%223341.466552734375_48_1193_16%22%20jivemacro_uid%3D%22_14545197350794854%22%3E%24%20nfcDemoApp%E3%81%AE%E6%8A%95%E7%A5%A8%3C%2FPRE%3ENFC%E3%83%AA%E3%83%BC%E3%83%80%E3%83%BC%E3%81%AE%E9%9A%A3%E3%81%ABNFC%E3%82%BF%E3%82%B0%E3%82%92%E9%85%8D%E7%BD%AE%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AB%E7%A4%BA%E3%81%99%E3%82%88%E3%81%86%E3%81%AA%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%E5%87%BA%E5%8A%9B%E3%81%8C%E5%BE%97%E3%82%89%E3%82%8C%E3%82%8B%E3%81%AF%E3%81%9A%E3%81%A7%E3%81%99%E3%80%82%20%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_0.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_0.png%22%20style%3D%22width%3A%20824px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F54957iE4121C668452F1B2%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_0.png%22%20alt%3D%22pastedImage_0.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FOL%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E7.%20%E5%8F%82%E8%80%83%E6%96%87%E7%8C%AE%20%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-329597%22%20target%3D%22_blank%22%3ENFC%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BC%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E3%81%A8KSDK%E3%81%AE%E7%B5%B1%E5%90%88%3C%2FA%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22http%3A%2F%2Fwww.nxp.com%2Fdocuments%2Fapplication_note%2FAN11697.pdf%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20title%3D%22http%3A%2F%2Fwww.nxp.com%2Fdocuments%2Fapplication_note%2FAN11697.pdf%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fwww.nxp.com%2Fdocuments%2Fapplication_note%2FAN11697.pdf%3C%2FA%3E%3C%2FP%3E%3CP%3E%3CA%20href%3D%22http%3A%2F%2Fwww.nxp.com%2Fdocuments%2Fuser_manual%2FUM10878.pdf%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20title%3D%22http%3A%2F%2Fwww.nxp.com%2Fdocuments%2Fuser_manual%2FUM10878.pdf%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fwww.nxp.com%2Fdocuments%2Fuser_manual%2FUM10878.pdf%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1106671%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX6_All%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3ELinux%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EYocto%20Project%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1106689%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3Ai.MX6Q%E4%B8%8A%E3%81%AENFCN7120%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1106689%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3Elinux_linnfc-nci%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E3%82%92%E3%82%AC%E3%82%A4%E3%83%89%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82nfcDemoApp%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3EnfcDemoApp%3A%20%E5%85%B1%E6%9C%89%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E3%81%AE%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%81%BF%E4%B8%AD%E3%81%AB%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3A%20%2Fusr%2Flib%2Flibnfc_nci_linux-1.so%3A%E5%86%85%E9%83%A8%E3%82%A8%E3%83%A9%E3%83%BC%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1106688%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3Ai.MX6Q%E4%B8%8A%E3%81%AENFCN7120%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1106688%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20KunYi%20Chen%2C%3C%2FP%3E%3CP%3E%E3%81%94%E5%9B%9E%E7%AD%94%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%E3%80%81%E6%AD%A3%E8%A6%8F%E8%A1%A8%E7%8F%BE%E3%80%81GPIO%E3%83%94%E3%83%B3%E3%81%A8%E3%81%AF%E5%88%A5%E3%81%AB%E3%80%81%E7%A7%81%E3%81%AB%E8%BF%94%E4%BF%A1%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Enfc%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%82%8BLinux%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%A8%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E7%9F%A5%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E7%A7%81%E3%81%AFLinux%E3%81%A7%E5%83%8D%E3%81%84%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EDooty.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1106687%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3Ai.MX6Q%E4%B8%8A%E3%81%AENFCN7120%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1106687%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%95%E3%81%A6%E3%80%81NXP%20PN7120A0EV%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%81%AE%E3%81%A7%E3%80%81%E6%9C%80%E5%88%9D%E3%81%AB%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%20%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E8%A8%98%E4%BA%8B%E3%81%A7%E3%81%AF%E3%80%81GPIO5_IO22%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E9%85%8D%E7%B7%9A%E6%96%B9%E6%B3%95%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%80%81%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%A8%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%84%E3%83%AA%E3%83%BC%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E6%8E%A5%E7%B6%9A%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EAOSP%3A%20Android%20%E3%82%AA%E3%83%BC%E3%83%97%E3%83%B3%E3%82%BD%E3%83%BC%E3%82%B9%20%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1106686%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3Ai.MX6Q%E4%B8%8A%E3%81%AENFCN7120%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1106686%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20KunYi%20Chen%2C%3C%2FP%3E%3CP%3E%E3%81%94%E5%9B%9E%E7%AD%94%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82AOSP%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%A8%E3%81%AF%E3%80%82%E7%A7%81%E3%81%AF%E3%80%81%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%83%BC%E3%81%8C%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E8%A8%AD%E8%A8%88%E3%81%AB%E4%BE%9D%E5%AD%98%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E5%BF%85%E8%A6%81%E3%81%AA%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E3%81%AB%E5%90%8C%E6%84%8F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%93%E3%81%A7%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AF%E3%81%93%E3%81%AE%E8%A8%98%E4%BA%8B%E3%81%8CPN71xx%E7%94%A8%E3%81%A7%E3%81%82%E3%82%8A%E3%80%81PN54x%E7%94%A8%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%84%E3%81%A8%E8%A8%80%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81git%E3%83%AA%E3%83%9D%E3%82%B8%E3%83%88%E3%83%AA%E3%81%8B%E3%82%89%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%82%A2%E3%82%A6%E3%83%88%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81nxp-pn5xx%E3%81%AE%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%8C%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%95%E3%82%8C%E3%80%81%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AFnfcDemoApp(linux_libnfc-nci)%E3%81%A7%E3%81%99%E3%80%82%E6%AC%A1%E3%81%AB%E3%80%81PN71xx%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%AE%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%82%B3%E3%83%BC%E3%83%89%E5%90%8Dpn544%E3%81%8C%E8%BF%BD%E5%8A%A0%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E7%90%86%E7%94%B1%E3%80%82%E5%B0%91%E3%81%97%E6%B7%B7%E4%B9%B1%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%93%E3%81%A7%E3%81%AF%E3%80%81%E6%AD%A3%E7%A2%BA%E3%81%AAnfc%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%AE%E9%83%A8%E5%93%81%E7%95%AA%E5%8F%B7%E3%81%AFnxp%20PN7120A0EV%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81SODIMM%20iMx6Dualite%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%E3%81%AEi2c%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%82%A4%E3%82%B9%E3%82%92%E4%BB%8B%E3%81%97%E3%81%A6%E6%8E%A5%E7%B6%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%E3%81%93%E3%81%AE%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3A-%20%3CA%20class%3D%22jive-link-external-small%22%20data-content-finding%3D%22Community%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttp%253A%252F%252Fwww.nxp.com%252Fdocuments%252Fapplication_note%252FAN11697.pdf%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fwww.nxp.com%2Fdocuments%2Fapplication_note%2FAN11697.pdf%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%A0%E3%81%8B%E3%82%89%E3%80%81%E7%A7%81%E3%81%8C%E5%85%88%E3%81%AB%E9%80%B2%E3%82%93%E3%81%A7%E3%80%81%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%A8nfcDemoApp%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AE%E4%B8%8A%E8%A8%98%E3%81%AEgit%E3%83%AA%E3%83%9D%E3%82%B8%E3%83%88%E3%83%AA%E3%82%92%E9%80%B2%E3%82%81%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AF%E3%81%9D%E3%82%8C%E3%81%9E%E3%82%8C%E3%81%AENFC%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB(PN7120A0EV)%E3%81%AE%E7%95%B0%E3%81%AA%E3%82%8B%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%89(%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%A8%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3)%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E4%BB%96%E3%81%AE%E6%8F%90%E6%A1%88%E3%82%92%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%80%81%E7%A7%81%E3%81%AB%E6%8F%90%E6%A1%88%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EDooty.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1106685%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3Ai.MX6Q%E4%B8%8A%E3%81%AENFCN7120%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1106685%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%83%89%E3%82%A5%E3%83%BC%E3%83%86%E3%82%A3%E3%80%81%3C%2FP%3E%3CP%3EPN54x%E3%81%A7%E6%9C%89%E5%8A%B9%E3%81%AA%E3%82%B7%E3%83%BC%E3%82%B1%E3%83%B3%E3%82%B9%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AE%E3%81%9F%E3%82%81%E3%80%81AOSP%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E6%9C%89%E5%8A%B9%E3%81%AA%E3%83%94%E3%83%B3%E3%82%92%E6%8C%81%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E3%81%A0%E3%81%91%E3%81%A7%E3%80%81%E3%81%9D%E3%82%8C%E3%81%AF%E4%BE%9D%E5%AD%98%E6%80%A7%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E8%A8%AD%E8%A8%88%E3%81%A7%E3%81%99%20%3C%2FP%3E%3CP%3E%E3%81%9D%E3%81%97%E3%81%A6%E3%80%81PN54x%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8FPN71xx%E3%81%A0%E3%81%91%E3%81%AE%E8%A8%98%E4%BA%8B%3C%2FP%3E%3CP%3E%E4%BB%96%E3%81%AE%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%83%BC%E5%88%B6%E5%BE%A1%E3%83%94%E3%83%B3%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AE%E3%80%8Cenable-gpio%E3%80%8D%E3%82%92%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%81%97%E3%81%A6%E3%81%8B%E3%82%89%E3%80%81%E5%90%8C%E3%81%98%E5%A0%B4%E6%89%80%E3%81%AB%E4%BB%96%E3%81%AE%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%83%BC%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1106684%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3Ai.MX6Q%E4%B8%8A%E3%81%AENFCN7120%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1106684%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%AF%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20%E3%83%84%E3%83%AA%E3%83%BC%E3%81%8B%E3%82%89%20NFC%20%E3%81%AE%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%83%BC%E3%81%AB%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%81%93%E3%81%93%E3%81%A7%E3%81%AF%E3%80%81%E3%81%9D%E3%82%8C%E3%82%89%E3%81%AE%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%83%BC%E5%90%8D%E3%81%AF%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20%E3%83%84%E3%83%AA%E3%83%BC%20%E3%82%B3%E3%83%BC%E3%83%89%E3%81%A7%E3%81%AF%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%A9%E3%81%AA%E3%81%9F%E3%81%8B%E3%80%81dtsi%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AB%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%83%BC%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%99%E3%82%8B%E3%81%AE%E3%82%92%E6%89%8B%E4%BC%9D%E3%81%A3%E3%81%A6%E3%82%82%E3%82%89%E3%81%88%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82Linux%203.10.53%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%92%E6%90%AD%E8%BC%89%E3%81%97%E3%81%9FSODIMM%20iMx6Dualite%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E(pn544_enable)%20-%20%26gt%3B%20(dev-%26gt%3Bpvdd_reg%E3%80%81dev-%26gt%3Bvbat_reg%E3%80%81dev-%26gt%3Bpmuvcc_reg%E3%80%81dev-%26gt%3Bsevdd_reg)%20%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%80%82%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%81%AF%E3%80%81%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%84%E3%83%AA%E3%83%BC%E3%81%A7%E5%89%B2%E3%82%8A%E5%BD%93%E3%81%A6%E3%82%89%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82NFC%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E6%9C%AC%E5%BD%93%E3%81%AB%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%E3%81%8B%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EDooty.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1106683%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3Ai.MX6Q%E4%B8%8A%E3%81%AENFCN7120%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1106683%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%94%E5%8F%82%E8%80%83%E3%81%BE%E3%81%A7%E3%81%AB%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%82%E3%82%8C%E3%81%B0%E3%80%81PN544%E3%81%AE%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%A8%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%2F%20FRI-SDK%E3%81%AE%E5%85%A5%E6%89%8B%E6%96%B9%E6%B3%95%E3%82%92%E6%95%99%E3%81%88%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AE%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%AFMP%E3%82%B9%E3%83%86%E3%83%BC%E3%82%B8%E3%81%AB%E5%85%A5%E3%82%8B%E3%81%AE%E3%81%A7%E3%80%81%3C%2FP%3E%3CP%3EAOSP%20%E3%81%AE%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%89%E3%81%8B%E3%82%89%E3%80%81PN544%20%E3%81%A8%20neard%20%E3%81%A8%20neardal%20%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%82%92%E7%A7%81%E3%81%AE%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%A7%E5%AE%9F%E8%A1%8C%E5%8F%AF%E8%83%BD%E3%81%AB%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1106682%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3Ai.MX6Q%E4%B8%8A%E3%81%AENFCN7120%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1106682%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EPN7150%20NFC%E3%83%87%E3%83%A2%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E4%BD%BF%E7%94%A8%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%E3%81%93%E3%81%AE%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%AB%E9%96%A2%E9%80%A3%E3%81%99%E3%82%8B%E6%AC%A1%E3%81%AE%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fdocs%2FDOC-331906%22%20target%3D%22_blank%22%3Ei.MX6SX%E4%B8%8A%E3%81%AEPN7150%20NFC%3C%2FA%3E%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1106681%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3Ai.MX6Q%E4%B8%8A%E3%81%AENFCN7120%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1106681%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Alejandor%2C%3C%2FP%3E%3CP%3E%E3%81%95%E3%81%A6%E3%80%81%E7%A7%81%E3%81%AF%E3%81%AA%E3%81%9C%E4%BB%8ANXP%20PN544%E3%81%AB%E5%8F%96%E3%82%8A%E7%B5%84%E3%81%BE%E3%81%AA%E3%81%84%E3%81%AE%E3%81%8B%E7%9F%A5%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99!%3C%2FP%3E%3CP%3EPN7120%E3%81%AFNFC%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A9%E3%83%A0%2FNCI%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%83%99%E3%83%BC%E3%82%B9%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%20%3C%2FP%3E%3CP%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81PN544%E3%81%AFETSI%20%2F%20HCI%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%20%3C%2FP%3E%3CP%3EI2C%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%2F%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%E5%BD%A2%E5%BC%8F%E3%81%AF%E3%81%BE%E3%81%A3%E3%81%9F%E3%81%8F%E7%95%B0%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1106680%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3Ai.MX6Q%E4%B8%8A%E3%81%AENFCN7120%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1106680%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Alejandor%2C%20%3C%2FP%3E%3CP%3E%E4%BB%8A%E6%97%A5%E7%A7%81%E3%81%AF%E3%81%93%E3%82%8C%E3%82%92%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%81%97%E3%81%BE%E3%81%99%E3%80%81I2C%E3%83%90%E3%82%B9%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%8C%E5%A5%BD%E3%81%8D%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%81PN544%E3%83%81%E3%83%83%E3%83%97%E3%81%8C%E5%BF%9C%E7%AD%94%E3%81%97%E3%81%AA%E3%81%84%E3%81%AA%E3%81%A9%E3%80%81%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AElibnfc-nxp%E3%81%AF%E5%BF%9C%E7%AD%94%E3%82%92%E5%8F%96%E5%BE%97%E3%81%97%E3%81%9F%E3%81%84%E3%81%AE%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E5%BF%9C%E7%AD%94%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Elibnfc-nxp.conf%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%A6%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%8C3%E3%83%90%E3%82%A4%E3%83%88%E3%81%AE%E5%BF%9C%E7%AD%94%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8D%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%E4%BB%A5%E5%89%8D%E3%81%AB%E3%80%8C20%2000%2001%2001%E3%80%8D%E3%82%92PN544%E3%81%AB%E9%80%81%E4%BF%A1%E3%81%97%E3%81%9F%E5%A0%B4%E5%90%88%E3%80%81%3C%2FP%3E%3CP%3E%E3%80%8C20%2000%2001%2001%E3%80%8D%E3%81%8C%E3%81%A9%E3%81%86%E3%81%84%E3%81%86%E6%84%8F%E5%91%B3%E3%81%8B%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3CP%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81PN544%E3%81%A7%E3%81%AF%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8C%E5%8F%97%E3%81%91%E5%85%A5%E3%82%8C%E3%82%89%E3%82%8C%E3%81%AA%E3%81%84%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%3C%2FP%3E%3CP%3E%23%23%20pn54x_dev_open%20%3A%2010%2C56%3C%2FP%3E%3CP%3Epn54x_dev_ioctl%E3%80%81cmd%3D1074063617%E3%80%81arg%3D1%3C%2FP%3E%3CP%3E%E9%9B%BB%E6%BA%90%E3%82%AA%E3%83%B3pn544_enable%20NFC%E3%83%87%E3%83%A2%3C%2FP%3E%3CP%3E%23%23%3C%2FP%3E%3CP%3E%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%3C%2FP%3E%3CP%3E%23%23%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Poll%20mode%20activated%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%23%23%3C%2FP%3E%3CP%3E%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%3C%2FP%3E%3CP%3E...Enter%E3%82%AD%E3%83%BC%E3%82%92%E6%8A%BC%E3%81%97%E3%81%A6%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%99...%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ENxpHal%3AphNxpNciHal_init_monitor%E3%81%AB%E5%85%A5%E3%82%8B%3C%2FP%3E%3CP%3ENxpHal%3A%E6%88%90%E5%8A%9F%E3%81%A7%E6%88%BB%E3%81%A3%E3%81%A6%E3%81%8F%E3%82%8B%3C%2FP%3E%3CP%3ENxpTml%3A%20%E3%83%9D%E3%83%BC%E3%83%88%E3%82%92%E9%96%8B%E3%81%8F%3D%2Fdev%2Fpn544%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ENxpTml%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20phTmlNfc_i2c_reset()%2C%20VEN%20level%201%3C%2FP%3E%3CP%3ENxpTml%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20pn54x_dev_ioctl%2C%20cmd%3D1074063617%2C%20arg%3D0%3C%2FP%3E%3CP%3EphTmlNfc_i2c_reset()%E3%80%81VEN%E3%83%AC%E3%83%99%E3%83%AB0pn544_disable%E9%9B%BB%E6%BA%90%E3%82%AA%E3%83%95%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ENxpTml%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20pn54x_dev_ioctl%2C%20cmd%3D1074063617%2C%20arg%3D1%3C%2FP%3E%3CP%3EphTmlNfc_i2c_reset()%E3%80%81%E9%9B%BB%E6%BA%90%E3%82%AA%E3%83%B31pn544_enable%20VEN%E3%83%AC%E3%83%99%E3%83%AB%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ENxpTml%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20i2c-%26gt%3B%3A00000000%3A%2020%2000%2001%2001%3C%2FP%3E%3CP%3EPN54X%20-%20TML%20%E3%83%AA%E3%83%BC%E3%83%80%E3%83%BC%20%E3%82%B9%E3%83%AC%E3%83%83%E3%83%89%E3%81%8C%E9%96%8B%E5%A7%8B%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F................%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ENxpTml%3A%20PN54X%20-%20TML%20%E3%83%A9%E3%82%A4%E3%82%BF%E3%83%BC%20%E3%82%B9%E3%83%AC%E3%83%83%E3%83%89%E3%81%8C%E9%96%8B%E5%A7%8B%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F................%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ENxpTml%3A%20PN54X%20-%20Tml%20%E3%83%A9%E3%82%A4%E3%82%BF%E3%83%BC%20%E3%82%B9%E3%83%AC%E3%83%83%E3%83%89%E3%81%8C%E5%AE%9F%E8%A1%8C%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99................%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ENxpTml%3A%20NxpHal%3A%20PN54X%20-%20%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%81%8C%E8%A6%81%E6%B1%82%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F.....%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ENxpTml%3A%20PN54X%20-%20I2C%20%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%81%AE%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97.....%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%B9%E3%83%AC%E3%83%83%E3%83%89%E3%81%8C%E9%96%8B%E5%A7%8B%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3ENxpTml%3A%20PN54X%20-%20%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%8C%E8%A6%81%E6%B1%82%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F.....%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ENxpTml%3A%20PN54X%20-%20I2C%20%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%AE%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97.....%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ENxpTml%3A%20PN54X%20-%20I2C%20%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%81%AB%E6%88%90%E5%8A%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F.....%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ENxpTml%3A%20PN54X%20-%20Posting%20Fresh%20Write%20%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8.....%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ENxpTml%3A%20PN54X%20-%20Tml%20%E3%83%A9%E3%82%A4%E3%82%BF%E3%83%BC%20%E3%82%B9%E3%83%AC%E3%83%83%E3%83%89%E3%81%8C%E5%AE%9F%E8%A1%8C%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99................%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ENxpHal%3A%20%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E6%88%90%E5%8A%9F%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%20%3D%200x0%3C%2FP%3E%3CP%3ENxpHal%3A%E3%83%AC%E3%82%B9%E3%83%9D%E3%83%B3%E3%82%B9%E3%82%BF%E3%82%A4%E3%83%9E%E3%83%BC%E9%96%8B%E5%A7%8B%3C%2FP%3E%3CP%3ENxpHal%3A%20ext%20cmd%20%E3%81%8C%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%81%9F%E5%BE%8C%E3%81%AB%E5%BE%85%E6%A9%9F%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3ENxpHal%3A%20pn54x_dev_ioctl%E3%80%81cmd%3D1074063617%E3%80%81arg%3D1%3C%2FP%3E%3CP%3Ehal_extns_write_rsp_timeout_cb%20-%20%E9%9B%BB%E6%BA%90%E3%82%AA%E3%83%B3pn544_enable%3C%2FP%3E%3CP%3E%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88!!%3C%2FP%3E%3CP%3ENxpHal%3A%E5%BF%9C%E7%AD%94%E3%82%BF%E3%82%A4%E3%83%9E%E3%83%BC%E3%81%8C%E5%81%9C%E6%AD%A2%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3ENxpHal%3A%20%E3%82%B3%E3%83%BC%E3%83%AB%E3%83%90%E3%83%83%E3%82%AF%20%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F!!%E3%82%BF%E3%82%A4%E3%83%9E%E3%83%BC%E5%88%87%E3%82%8C!!%E8%AA%AD%E3%82%81%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F!0xff%3C%2FP%3E%3CP%3ENxpHal%3A%20NCI_CORE_RESET%3A%20%E5%A4%B1%E6%95%97%3C%2FP%3E%3CP%3ENxpHal%3A%E3%83%91%E3%83%AF%E3%83%BC%E3%82%B5%E3%82%A4%E3%82%AF%E3%83%AB%3C%2FP%3E%3CP%3ENxpTml%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20phTmlNfc_i2c_reset()%2C%20VEN%20level%201%3C%2FP%3E%3CP%3ENxpTml%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20pn54x_dev_ioctl%2C%20cmd%3D1074063617%2C%20arg%3D0%3C%2FP%3E%3CP%3EphTmlNfc_i2c_reset()%E3%80%81VEN%E3%83%AC%E3%83%99%E3%83%AB0pn544_disable%E9%9B%BB%E6%BA%90%E3%82%AA%E3%83%95%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3ENxpTml%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20_i2c_read()%20%5Bhdr%5D%20errno%20%3A%205%3C%2FP%3E%3CP%3ENxppn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3ETml%3A%20PN54X%20-%20I2C%20Reapn54x_dev_read%20%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%3A%20i2c_master_recv%20-5%20%E3%81%8C%E8%BF%94%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3Ed.....%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ENxpTml%3A%20PN54X%20-%20Reapn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Ed%20%E3%81%8C%E8%A6%81%E6%B1%82%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F.....%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ENxpTml%3A%20Ppn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3EN54X%20-%20I2C%20%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%AE%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97.....%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3ENxpTml%3A%20_i2c_read()%20%5Bhdr%5D%20errpn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Eno%20%3A%205%3C%2FP%3E%3CP%3ENxpTml%3A%20PN54X%20-%20Errorpn54x_dev_read%3A%20i2c_master_recv%20-5%20%E8%BF%94%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%20I2C%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%A7.....%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ENxpTml%3A%20pn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3EPN54X%20-%20%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%8C%E8%A6%81%E6%B1%82%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F.....%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ENxpn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1106679%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3Ai.MX6Q%E4%B8%8A%E3%81%AENFCN7120%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1106679%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Alejandor%2C%3C%2FP%3E%3CP%3E%E3%81%BE%E3%81%9A%E3%81%AF%E3%80%81%E3%81%8A%E8%BF%94%E4%BA%8B%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99!%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AB%E7%9F%A5%E3%82%89%E3%81%9B%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E4%BD%95%E3%81%8B%E3%82%92%E8%AA%AC%E6%98%8E%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81PN7120%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8FPN544%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%BE%E3%81%9F%E3%80%81Linux%20NFC%E3%82%B5%E3%83%96%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%92%E3%83%86%E3%82%B9%E3%83%88%E3%81%97%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AEpn544%E3%81%AFI2C%E3%81%A7%E3%81%BE%E3%81%A0%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%E3%82%A4%E3%83%8B%E3%82%B7%E3%82%A8%E3%83%BC%E3%82%BF%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A7%E5%8B%95%E4%BD%9C%E3%81%97%E3%80%81%E5%BF%9C%E7%AD%94%E3%82%BF%E3%82%B0%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3CP%3E%E3%81%A0%E3%81%8B%E3%82%89%E3%80%81I2C%E3%83%90%E3%82%B9%E3%81%AF%E3%81%86%E3%81%BE%E3%81%8F%E6%A9%9F%E8%83%BD%E3%81%99%E3%82%8B%E3%81%AF%E3%81%9A%E3%81%A0%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%3E%E8%A9%B3%E7%B4%B0%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%E3%81%93%E3%81%AE%20%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-thread-small%22%20data-containerid%3D%222004%22%20data-containertype%3D%2214%22%20data-objectid%3D%22385569%22%20data-objecttype%3D%221%22%20href%3D%22https%3A%2F%2Fcommunity.freescale.com%2Fthread%2F385569%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.freescale.com%2Fthread%2F385569%3C%2FA%3E%3CSPAN%3E%20%E3%81%A8%20%3C%2FSPAN%3E%3CA%20href%3D%22http%3A%2F%2Fpastebin.com%2F3NsUTgAf%22%20title%3D%22http%3A%2F%2Fpastebin.com%2F3NsUTgAf%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Eneard_pn544_dmesg_kunyi%20-%20Pastebin.com%3C%2FA%3E%20%E3%82%92%E3%81%94%E8%A6%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%A8%E3%81%93%E3%82%8D%E3%81%A7%E3%80%81l%E3%81%AF%E4%BB%8A%E3%80%81%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%AE%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E3%81%A7I2C%E3%83%90%E3%82%B9%E4%BF%A1%E5%8F%B7%E3%82%92%E5%86%8D%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1106678%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3Ai.MX6Q%E4%B8%8A%E3%81%AENFCN7120%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1106678%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AF%E3%80%81%E3%81%94%E6%83%B3%E5%83%8F%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%80%81i2c%E9%80%9A%E4%BF%A1%E3%81%AB%E9%96%A2%E9%80%A3%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82PN7120%E3%81%8C%E6%AD%A3%E5%B8%B8%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3Ei2c%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%84%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%81%AF%E3%80%81%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%97%E3%81%BE%E3%81%9F%E3%81%AF%E3%83%AD%E3%82%B8%E3%83%83%E3%82%AF%E3%82%A2%E3%83%8A%E3%83%A9%E3%82%A4%E3%82%B6%E3%83%BC%E3%81%A7%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E3%81%8A%E5%8B%A7%E3%82%81%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EAlejandro%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1106677%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3Ai.MX6Q%E4%B8%8A%E3%81%AENFCN7120%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1106677%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E7%8F%BE%E5%9C%A8%E3%80%81%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AFVEN%E3%81%A8PMUVCC%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%82%92%E5%88%86%E5%89%B2%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%20VBAT%2FPMUVCC%E6%8E%A5%E7%B6%9A%E3%81%AEVEN%E3%81%AF%E3%80%81%E5%B8%B8%E3%81%AB%E3%80%8Cpn54x_dev_read%EF%BC%9Ai2c_master_recv%E8%BF%94%E3%81%95%E3%82%8C%E3%81%9F-5%E3%80%8D%E6%96%87%E5%AD%97%E5%88%97%E3%82%92%E5%87%BA%E5%8A%9B%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%E7%8F%BE%E5%9C%A8%E3%81%AEPMUVCC%20%2F%20VBAT%E3%81%AF%E5%B8%B8%E3%81%AB%E4%BE%9B%E7%B5%A6%E3%82%92%E7%B6%AD%E6%8C%81%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3EVEN%E3%83%94%E3%83%B3%E3%82%92%E5%88%B6%E5%BE%A1%E3%81%99%E3%82%8B%E3%81%A0%E3%81%91%3C%2FP%3E%3CP%3E%E6%96%B0%E3%81%97%E3%81%84%E7%B5%90%E6%9E%9C%E3%82%92%E5%8F%96%E5%BE%97%E3%81%97%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81nfcDemoApp%20poll%20%E3%81%AE%E5%AE%9F%E8%A1%8C%E6%99%82%E3%81%AB%E3%80%8C%E9%9B%BB%E6%BA%90%E3%82%AA%E3%83%B3pn544_enable%E3%80%8D%E3%81%A7%E4%BF%9D%E7%95%99%E4%B8%AD%E3%80%81%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%3C%2FP%3E%3CP%3E%23%23%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20NFC%20demo%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%23%23%3C%2FP%3E%3CP%3E%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%3C%2FP%3E%3CP%3E%23%23%20%E3%83%9D%E3%83%BC%E3%83%AA%E3%83%B3%E3%82%B0%E3%83%A2%E3%83%BC%E3%83%89%20actipn54x_dev_open%20%3A%2010%2C56%3C%2FP%3E%3CP%3Epn54x_dev_ioctl%E3%80%81cmd%3D1074063617%E3%80%81arg%3D1%3C%2FP%3E%3CP%3E%23%23%3C%2FP%3E%3CP%3E%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23pn544_enable%20%E9%9B%BB%E6%BA%90%E3%82%AA%E3%83%B3%3C%2FP%3E%3CP%3E%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%3C%2FP%3E%3CP%3E...Enter%E3%82%AD%E3%83%BC%E3%82%92%E6%8A%BC%E3%81%97%E3%81%A6%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%99...%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Epn54x_dev_ioctl%E3%80%81cmd%3D1074063617%E3%80%81arg%3D0%3C%2FP%3E%3CP%3Epn544_disable%E9%9B%BB%E6%BA%90%E3%82%92%E5%88%87%E3%82%8B%3C%2FP%3E%3CP%3Epn54x_dev_ioctl%E3%80%81cmd%3D1074063617%E3%80%81arg%3D1%3C%2FP%3E%3CP%3E%E9%9B%BB%E6%BA%90%E3%82%AA%E3%83%B3pn544_enable%3C%2FP%3E%3CP%3Epn54x_dev_ioctl%E3%80%81cmd%3D1074063617%E3%80%81arg%3D1%3C%2FP%3E%3CP%3E%E9%9B%BB%E6%BA%90%E3%82%AA%E3%83%B3pn544_enable%3C%2FP%3E%3CP%3Epn54x_dev_ioctl%E3%80%81cmd%3D1074063617%E3%80%81arg%3D0%3C%2FP%3E%3CP%3Epn544_disable%E9%9B%BB%E6%BA%90%E3%82%92%E5%88%87%E3%82%8B%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_ioctl%E3%80%81cmd%3D1074063617%E3%80%81arg%3D1%3C%2FP%3E%3CP%3E%E9%9B%BB%E6%BA%90%E3%82%AA%E3%83%B3pn544_enable%3C%2FP%3E%3CP%3Epn54x_dev_ioctl%E3%80%81cmd%3D1074063617%E3%80%81arg%3D1%3C%2FP%3E%3CP%3E%E9%9B%BB%E6%BA%90%E3%82%AA%E3%83%B3pn544_enable%3C%2FP%3E%3CP%3Epn54x_dev_ioctl%E3%80%81cmd%3D1074063617%E3%80%81arg%3D0%3C%2FP%3E%3CP%3Epn544_disable%E9%9B%BB%E6%BA%90%E3%82%92%E5%88%87%E3%82%8B%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_ioctl%E3%80%81cmd%3D1074063617%E3%80%81arg%3D1%3C%2FP%3E%3CP%3E%E9%9B%BB%E6%BA%90%E3%82%AA%E3%83%B3pn544_enable%3C%2FP%3E%3CP%3Epn54x_dev_ioctl%E3%80%81cmd%3D1074063617%E3%80%81arg%3D1%3C%2FP%3E%3CP%3E%E9%9B%BB%E6%BA%90%E3%82%AA%E3%83%B3pn544_enable%3C%2FP%3E%3CP%3Epn54x_dev_ioctl%E3%80%81cmd%3D1074063617%E3%80%81arg%3D0%3C%2FP%3E%3CP%3Epn544_disable%E9%9B%BB%E6%BA%90%E3%82%92%E5%88%87%E3%82%8B%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_ioctl%E3%80%81cmd%3D1074063617%E3%80%81arg%3D1%3C%2FP%3E%3CP%3E%E9%9B%BB%E6%BA%90%E3%82%AA%E3%83%B3pn544_enable%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1106676%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3Ai.MX6Q%E4%B8%8A%E3%81%AENFCN7120%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1106676%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%3C%2FP%3E%3CP%3EPN544%20(base%203.14.52_v1.1.0qa%20%E3%82%92%E6%90%AD%E8%BC%89%E3%81%97%E3%81%9F%20IMX6DL%20%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E3%81%A7%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%BF%E3%81%9F%E3%81%84%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82)%3C%2FP%3E%3CP%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99!%3C%2FP%3E%3CP%3Einsmod%20%2Flib%2Fmodules%2F3.14.52%2Bg92a293a%2Fkernel%2Fdrivers%2Fmisc%2Fpn5x%3C%2FP%3E%3CP%3Epn54x_dev_init%3C%2FP%3E%3CP%3Epn54x_probe%3C%2FP%3E%3CP%3Epn54x%200-0028%3A%20CLKREQ%20GPIO%20OF%3COPTIONAL%3E%20%E3%83%8E%E3%83%BC%E3%83%89%E3%81%8B%E3%82%89%E3%81%AE%E5%8F%96%E5%BE%97%E3%82%A8%E3%83%A9%E3%83%BC%3C%2FOPTIONAL%3E%3C%2FP%3E%3CP%3E0-0028%20%E9%9B%BB%E6%BA%90NXP%E3%80%81PN54X-PVDD%20%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%81%E3%83%80%E3%83%9F%E3%83%BC%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%82%92%E4%BD%BF%E7%94%A8%3C%2FP%3E%3CP%3E0-0028%20%E9%9B%BB%E6%BA%90NXP%E3%80%81PN54X-VBAT%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%81%E3%83%80%E3%83%9F%E3%83%BC%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%82%92%E4%BD%BF%E7%94%A8%3C%2FP%3E%3CP%3E0-0028%20%E9%9B%BB%E6%BA%90NXP%E3%80%81PN54X-PMUVCC%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%81%E3%83%80%E3%83%9F%E3%83%BC%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%82%92%E4%BD%BF%E7%94%A8%3C%2FP%3E%3CP%3E0-0028%20%E9%9B%BB%E6%BA%90%20NXP%E3%80%81PN54X-SEVDD%20%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%81%E3%83%80%E3%83%9F%E3%83%BC%20%E3%83%AC%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%82%92%E4%BD%BF%E7%94%A8%3C%2FP%3E%3CP%3Epn54x_probe%3A%20%E3%83%AA%E3%82%AF%E3%82%A8%E3%82%B9%E3%83%88%20irq_gpio%20159%3C%2FP%3E%3CP%3Epn54x_probe%3A%20request%20ven_gpio%205%3C%2FP%3E%3CP%3Epn54x_probe%3A%20%E3%83%AA%E3%82%AF%E3%82%A8%E3%82%B9%E3%83%88%20firm_gpio%20163%3C%2FP%3E%3CP%3Epn54x_probe%20%3A%20IRQ%20319%20%E3%81%AE%E3%83%AA%E3%82%AF%E3%82%A8%E3%82%B9%E3%83%88%3C%2FP%3E%3CP%3Eroot%40imx6dltinto%3A~%23%20nfcDemoApp%20poll%3C%2FP%3E%3CP%3E%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%3C%2FP%3E%3CP%3E%23%23%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20NFC%20demo%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%23%23%3C%2FP%3E%3CP%3E%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%3C%2FP%3E%3CP%3E%23%23%20%E3%83%9D%E3%83%BC%E3%83%AA%E3%83%B3%E3%82%B0%E3%83%A2%E3%83%BC%E3%83%89%20actpn54x_dev_open%20%3A%2010%2C56%3C%2FP%3E%3CP%3Eivated%20pn54x_dev_ioctl%2C%20cmd%3D1074063617%2C%20arg%3D1%3C%2FP%3E%3CP%3E%23%23%3C%2FP%3E%3CP%3E%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23pn544_enable%20%E9%9B%BB%E6%BA%90%E3%82%AA%E3%83%B3%3C%2FP%3E%3CP%3E%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%23%3C%2FP%3E%3CP%3E...Enter%E3%82%AD%E3%83%BC%E3%82%92%E6%8A%BC%E3%81%97%E3%81%A6%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%99...%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Epn54x_dev_ioctl%E3%80%81cmd%3D1074063617%E3%80%81arg%3D0%3C%2FP%3E%3CP%3Epn544_disable%E9%9B%BB%E6%BA%90%E3%82%92%E5%88%87%E3%82%8B%3C%2FP%3E%3CP%3Epn54x_dev_ioctl%E3%80%81cmd%3D1074063617%E3%80%81arg%3D1%3C%2FP%3E%3CP%3E%E9%9B%BB%E6%BA%90%E3%82%AA%E3%83%B3pn544_enable%3C%2FP%3E%3CP%3Epn54x_dev_ioctl%E3%80%81cmd%3D1074063617%E3%80%81arg%3D1%3C%2FP%3E%3CP%3E%E9%9B%BB%E6%BA%90%E3%82%AA%E3%83%B3pn544_enable%3C%2FP%3E%3CP%3Epn54x_dev_ioctl%E3%80%81cmd%3D1074063617%E3%80%81arg%3D0%3C%2FP%3E%3CP%3Epn544_disable%E9%9B%BB%E6%BA%90%E3%82%92%E5%88%87%E3%82%8B%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3Epn54x_dev_ioctl%E3%80%81cmd%3D1074063617%E3%80%81arg%3D1%3C%2FP%3E%3CP%3Epn54x_dev_read%3A%20i2c_master_recv%20-5%20%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%A9%E3%81%AA%E3%81%9F%E3%81%8B%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%99%E3%82%8B%E3%81%AE%E3%82%92%E6%89%8B%E4%BC%9D%E3%81%A3%E3%81%A6%E3%81%8F%E3%82%8C%E3%82%8B%E6%96%B9%E3%81%AF%E3%81%84%E3%82%89%E3%81%A3%E3%81%97%E3%82%83%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E........................%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1106675%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3Ai.MX6Q%E4%B8%8A%E3%81%AENFCN7120%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1106675%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%82%A2%E3%83%AC%E3%83%83%E3%82%AF%E3%82%B9%E3%80%81%E9%9D%9E%E5%B8%B8%E3%81%AB%E8%89%AF%E3%81%8F%E3%80%81%E3%82%88%E3%81%8F%E6%A7%8B%E9%80%A0%E5%8C%96%E3%81%95%E3%82%8C%E3%81%9F%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%80%82%3C%2FP%3E%3CP%3E%E3%80%8CAs%20you%20can%20see%20besides%20power%E3%80%8D%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E4%BA%8C%E4%BA%BA%E7%A7%B0%E3%81%AE%E6%96%87%E3%82%92%E3%80%8CAs%20shown%20besides%20power%E3%80%8D%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E9%9D%9E%E5%80%8B%E4%BA%BA%E7%9A%84%E3%81%AA%E6%96%87%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E3%81%8A%E5%8B%A7%E3%82%81%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1106674%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3Ai.MX6Q%E4%B8%8A%E3%81%AENFCN7120%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1106674%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E8%89%AF%E3%81%84%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E5%85%B1%E6%9C%89%E3%82%92%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%80%82%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1106673%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3Ai.MX6Q%E4%B8%8A%E3%81%AENFCN7120%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1106673%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%A8%E3%81%A6%E3%82%82%E3%81%84%E3%81%84%E6%84%9F%E3%81%98%E3%81%AB%E8%A6%8B%E3%81%88%E3%81%BE%E3%81%99%E3%80%81%20%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Falejandrolozano%22%20target%3D%22_blank%22%3Ealejandrolozano%3C%2FA%3E!%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%84%E3%83%AA%E3%83%BC%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E6%B7%BB%E4%BB%98%E3%81%97%E3%81%AA%E3%81%8B%E3%81%A3%E3%81%9F%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1106672%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3Ai.MX6Q%E4%B8%8A%E3%81%AENFCN7120%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1106672%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Fgusarambula%22%20target%3D%22_blank%22%3Egusarambula%3C%2FA%3E%2C%20%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Fjamesbone%22%20target%3D%22_blank%22%3Ejamesbone%3C%2FA%3E%E2%80%8B%2C%20%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2FCarlosCasillas%22%20target%3D%22_blank%22%3ECarlosCasillas%3C%2FA%3E%E2%80%8B%2C%20%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2Fjimmychan%22%20target%3D%22_blank%22%3Ejimmychan%3C%2FA%3E%E2%80%8B%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%83%89%E3%82%AD%E3%83%A5%E3%83%A1%E3%83%B3%E3%83%88%E3%82%92%E3%81%96%E3%81%A3%E3%81%A8%E8%A6%8B%E3%81%A6%E3%80%81%E3%83%95%E3%82%A3%E3%83%BC%E3%83%89%E3%83%90%E3%83%83%E3%82%AF%E3%82%92%E6%8F%90%E4%BE%9B%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EAlejandro%3C%2FP%3E%3C%2FLINGO-BODY%3E
評価なし
バージョン履歴
最終更新日:
‎09-10-2020 02:00 AM
更新者:
