S32 Design Studio for PA E200 V1.1 Instal Issue
fengge
    I instal S32 Design Studio for PA E200 V1.1 use offline for  activation.But the request.xml is always  wrong,I found that is different form right
Wrong is '<TrustedId>1</TrustedId><Revision>DefaultOne</Revision>'
Right is'<TrustedId>3</TrustedId><Revision>1</Revision>'
'<SequenceNumber>1</SequenceNumber>' is different too!
Could you help me?Thank you!
Original Attachment has been moved to: DC.zip
stanish
Hello Feng,
Thank you for the report.
I've checked all offline activation transactions on the licensing server and indeed there are indeed unsuccessful attempts due to TrustedID 1. This is a known issue in v1.1.
Therefore I'd recommend you to install the latest S32 Design Studio for Power v1.2
 S32 Design Studio for Power v1.2 (Windows/Linux) released!
since it should include offline activation issue fix.
https://community.nxp.com/docs/DOC-334344
v1.2 requires a different activation ID other then v1.1. You should receive a notification email that includes new activation ID as soon as you start downloading S32DS Power v1.2.
how can i get a activation id for S32DS?
I noticed that you were finally able to activate the product.
Anyway please let me know if there is any problem with installation/activation.
Stan
