i.MX6DQ OE and OC assert/negate timing in async mode.
satoshishimoda
Senior Contributor I
Hi community,
We have a question about i.MX6DQ EIM.
According to the figures in chapter 22.8 of IMX6DQRM Rev.3, OE and OC signal is asserted/negated at the rising edge of EIM CLK in asynchronous mode.
On the other hand, in IMX6DQCEC Rev.4, OE and OC signal is asserted/negated at the falling edge of INT_CLK.
Which is correct?
Satoshi Shimoda
Labels (4)
Hi Satoshi
correct is rising edge of EIM CLK, also datasheet pictures show
timing references to rising edge
Hi Satoshi
