i.MX6DQ OE and OC assert/negate timing in async mode.
1,320 次查看
satoshishimoda
Senior Contributor I
Hi community,
We have a question about i.MX6DQ EIM.
According to the figures in chapter 22.8 of IMX6DQRM Rev.3, OE and OC signal is asserted/negated at the rising edge of EIM CLK in asynchronous mode.
On the other hand, in IMX6DQCEC Rev.4, OE and OC signal is asserted/negated at the falling edge of INT_CLK.
Which is correct?
Satoshi Shimoda
标签 (4)
标记 (1)
1,114 次查看
igorpadykov
Hi Satoshi
correct is rising edge of EIM CLK, also datasheet pictures show
timing references to rising edge
1,115 次查看
igorpadykov
Hi Satoshi
