How to capture the Console in debugging a JTAG configuration issue
kbell_hardware
I'm trying to debug an issue where "CCSProtocolPlugin : Failed to correctly configure the JTAG chain" even though i've run the CCS IDcode.tcl and ir commands in the server and the chain looks fine. My JTAG chain text file matches the CW JTAG file format, i've even used the processor expert to output the file i need and it still doesn't work. I've enabled logging so i can catch where it fails in the console output but the console deletes everything automatically when it fails. I changed the settings so the console would output to a file but the file is always blank. How can i capture the log? I've tried selecting all and copying as fast as i can and what i get is pasted below. I'm trying to connect to a T2080 with the CodeWarrior TAP over USB.
I've done this multiple times, it appears to be normal that the connection is refused one or two times at first before it continues. It writes all of the RCW registers and appears to fail when resetting.....or at least that's what i could capture.
ccs_open
    ipaddr = 127.0.0.1
    port = 41475
    timeout = 15
    serverh = 0
    ccs_open; ccs_error = 10
    Error message: Connection refused
ccs_open
    ipaddr = 127.0.0.1
    port = 41475
    timeout = 15
    serverh = 0
ccs_open
    ipaddr = 127.0.0.1
    port = 41475
    timeout = 15
    serverh = 0
    ccs_open; ccs_error = 0
ccs_get_connection_count
    serverh = 0
    count = 1
    ccs_get_connection_count; ccs_error = 0
ccs_available_connections
    serverh = 0
    count = 0
    ccs_available_connections; ccs_error = 0
    serverh = 0
    count = 0
ccs_config_cc
    serverh = 0
    config_string = cwtap:0
    ccs_config_cc; ccs_error = 0
    serverh = 0
    count = 1
ccs_cc_version
    serverh = 0
    cc = 0
    version.major = 0
    version.minor = 0
    ccs_cc_version; ccs_error = 0
ccs_set_timeout
    serverh = 0
    timeout = 15
    ccs_set_timeout; ccs_error = 0
    serverh = 0
    count = 1
ccs_config_server
    serverh = 0
    cc = 0
    server_config = 0
    value = 10230
    ccs_config_server; ccs_error = 0
ccs_get_config_chain
    serverh = 0
    device_list: (size = 0)
    ccs_get_config_chain; ccs_error = 0
ccs_config_chain
    serverh = 0
    cc = 0
    device_list: (size = 1)
        device[0]:: core_type=T2080(242)
    ccs_config_chain; ccs_error = 0
ccs_config_template
    coreh = [serverh:0;cc_index:0;chain_pos:0]
    config_reg = 0
    config_data = 500
    ccs_config_template; ccs_error = 0
ccs_config_template
    config_reg = 2
    config_data = 1
ccs_write_register
    index = 210001
    count = 1
    size = 4
    value: (size = 4)
         0C00100F
    ccs_write_register; ccs_error = 0; duration=0 ms
ccs_write_register
    index = 210002
    count = 1
    size = 4
    value: (size = 4)
         05000000
ccs_write_register
    index = 210003
    count = 1
    size = 4
    value: (size = 4)
         00000000
    ccs_write_register; ccs_error = 0; duration=16 ms
ccs_write_register
    index = 210004
    count = 1
    size = 4
    value: (size = 4)
         00000000
ccs_write_register
    index = 210005
    count = 1
    size = 4
    value: (size = 4)
         6C2D0002
ccs_write_register
    index = 210006
    count = 1
    size = 4
    value: (size = 4)
         F0006A00
ccs_write_register
    index = 210007
    count = 1
    size = 4
    value: (size = 4)
         EC026000
ccs_write_register
    index = 210008
    count = 1
    size = 4
    value: (size = 4)
         C1000000
ccs_write_register
    index = 210009
    count = 1
    size = 4
    value: (size = 4)
         02180000
ccs_write_register
    index = 210010
    count = 1
    size = 4
    value: (size = 4)
         00000001
ccs_write_register
    index = 210011
    count = 1
    size = 4
    value: (size = 4)
         00000000
    ccs_write_register; ccs_error = 0; duration=15 ms
ccs_write_register
    index = 210012
    count = 1
    size = 4
    value: (size = 4)
         000197FC
    ccs_write_register; ccs_error = 0; duration=2 ms
ccs_write_register
    index = 210013
    count = 1
    size = 4
    value: (size = 4)
         00000100
ccs_write_register
    index = 210014
    count = 1
    size = 4
    value: (size = 4)
         5280000D
ccs_write_register
    index = 210015
    count = 1
    size = 4
    value: (size = 4)
         00000000
ccs_write_register
    index = 210016
    count = 1
    size = 4
    value: (size = 4)
         00000004
ccs_reset_to_debug
    serverh = 0
    cc = 0
kbell_hardware
I'm new to this environment so i didn't realize that their are multiple console screens and you have to switch back to your logging console to see it.
kbell_hardware
lunminliang
I think when you remove the termination, the log will show again on the console. No?
Lunmin
