Cannot run eIQ modelrunner
Hayder
In an attempt to run a model created through eIQ portal on the the 1050 board, I followed the eIQ Toolkit User Guide. It seemed to assume that I had the board connected to an http server, however, so I browsed the internet and found only this tutorial showing how to do that. The tutorial, however, is outdated, and so I am stuck with trying to run the model.
I tried accessing the board through the pc directly, which didn't work, and simply connecting via the COM5 port didn't work either, so I'm here asking for help on how can I profile with the modelrunner.
I also tried to run the model in my computer, but it also didn't work.
Thank you very much.
