hello~
i'm going to use vg_lite_blit to draw a image in RT1170 ,
but there are no demos about how to use this api.
it looks so strange that there is only one picture about the result.
anyone who can show me a demo will get 0.01eth for rewards,thank you so much~
Hi @hellogaogle
About the VGLITE blit, please refer to the API document:
https://www.nxp.com/webapp/Download?colCode=IMXRTVGLITEAPIRM&location=null
Chapter 8 BLITs for Compositing and Blending
You also can check the RT1170 SDK:
SDK_2_10_1_MIMXRT1170-EVK\boards\evkmimxrt1170\vglite_examples
in the vg_lite_text.c, it has some code about vg_lite_blit.
Wish it helps you!
Kerry
Hi, thank you for your reply. I am an engineer from HASCO, China. We are planning to use RT1176 to do a project, but we do not know how to import our image resources into the project, the demos we get are how to use SVG and evo FORMAT images but without any suggestions on how to convert images to the SVG and EVO format. I found there is a function called vg_lite_blit (vg_lite_blit_rect) which seems can load RGB data directly, but I get very few clues on how to use it. Can you send me a demo on how to display RGB data onto the display via vg_lite? Many thanks. "zhenyuf@hascovision.com"
thank you so much , i know the pdf you and the demo you mentioned ,but i still can't draw a image , i am now reading the memory of rt1170 know ,thank you anyway for your replying.
Hi @hellogaogle ,
Do you test it for your company or yourself?
As I find you are using the 3rd part qq email.
If you are working this issue for the company, I suggest you use the company email create a new case, and provide your issue project, then we can help you to check it in details. company email case will have more support resource than your low level qq email.
Wish it helps you!
Kerry
sounds great . Do you have an eth wallet? 0.02eth for rewards~
Hi @hellogaogle ,
User company email create the case, we can put more time for your technical issues, and have higher priority than the 3rd part email.
Wish it helps you!
Kerry
