vg_lite_blit,eth for rewards
1,813 次查看
hellogaogle
hello~
i'm going to use vg_lite_blit to draw a image in  RT1170 ,
but there are no  demos about how to use this api.
it looks so strange that there is only one picture about the result.
anyone who can show me a demo  will get 0.01eth for rewards,thank you so much~
6 回复数
1,798 次查看
kerryzhou
Hi @hellogaogle
  About the VGLITE blit, please refer to the API document:
https://www.nxp.com/webapp/Download?colCode=IMXRTVGLITEAPIRM&location=null
Chapter 8 BLITs for Compositing and Blending
You also can check the RT1170 SDK:
SDK_2_10_1_MIMXRT1170-EVK\boards\evkmimxrt1170\vglite_examples
in the vg_lite_text.c, it has some code about vg_lite_blit.
Wish it helps you!
Kerry
1,704 次查看
Nicegirl120
Hi, thank you for your reply. I am an engineer from HASCO, China. We are planning to use RT1176 to do a project, but we do not know how to import our image resources into the project, the demos we get are how to use SVG and evo FORMAT images but without any suggestions on how to convert images to the SVG and EVO format. I found there is a function called vg_lite_blit (vg_lite_blit_rect) which seems can load RGB data directly, but I get very few clues on how to use it. Can you send me a demo on how to display RGB data onto the display via vg_lite? Many thanks.    "zhenyuf@hascovision.com"
1,795 次查看
hellogaogle
thank you so much , i know the pdf you and the demo you mentioned ,but i still can't  draw a image , i am now reading  the memory of rt1170 know ,thank you anyway for your replying.
1,786 次查看
kerryzhou
Hi @hellogaogle ,
  Do you test it for your company or yourself?
   As I find you are using the 3rd part qq email.
  If you are working this issue for the company, I suggest you use the company email create a new case, and provide your issue project, then we can help you to check it in details. company email case will have more support resource than your low level qq email.
  Wish it helps you!
Kerry
1,781 次查看
hellogaogle
sounds great . Do you have  an eth wallet? 0.02eth for rewards~
1,775 次查看
kerryzhou
Hi @hellogaogle ,
  User company email create the case, we can put more time for your technical issues, and have higher priority than the 3rd part email.
 Wish it helps you!
Kerry
