My i.MX.RT1050 EVK board stucks in maintenance mode and I cannot use the debug port now, any idea how to recover it?
The DAP Link Port is connected to PC USB port.
Thanks!
Cindy
Solved! Go to Solution.
Hi @Cindy
Don't worry, in the maintenance, you need to send the firmware to that disk.
Please help to confirm, you are using the MIMXRT1050-EVK or MIMXRT1050-EVKB.
Then, go to this link:
As the MIMRT1050 EVK/EVKB is using the hyperflash, download the hyperflash firmware:
unzip it, you will get k20dx_mimxrt1050_evk_hyper_if_crc.bin, send this firmware to your MAINTENANCE, after it is finished, power off and power on again, you should can see the device:
Please try it on your side.
If you still have questions about it, please kindly let me know.
Kerry
Hi Kerry,
Thanks for your prompt reply. My problem has been resolved.
Great Thanks!
Cindy
Hi @Cindy
Kerry
