I observe that booting an encrypted image from SDRAM takes 45 seconds for about 2.5 MB. When I boot it as signed, it starts almost instantly - about 1 second. I am creating the image and flashing it with the MCUXpresso Secure Provisioning Tool v6.
The platform is:
I have tried to solve it but with no result. One thing is obvious - smaller encrypted image results in better boot time. I found nothing relevant on the internet, and I believe I am either doing something wrong or this timing is expected.
I would be glad for any advice or pattern to solve this issue.
Thank you.
Hello, I hope you are well.
It is expected that a encrypted and signed image consumes more time on booting, depending the size of the image this time will increment however I found 45 second odly as it is too much time even for encrypted image.
How you encrypted the image? Could you provide the steps followed or could you provide the a test code to reproduce it on the EVK?
Omar
