RT117x SDK: Bug in CLOCK_GetPllFreq(kCLOCK_PllArm)
705件の閲覧回数
udoeb
I found an issue in CLOCK_GetPllFreq():
In case kCLOCK_PllArm the line:
  postDiv = (1UL << (postDiv + 1UL));
does not handle POST_DIV_SEL=3 correctly. The code should be fixed as follows:
  postDiv = (postDiv == 3) ? 1 : (1UL << (postDiv + 1UL));
See also register ARM_PLL_CTRL in the manual.
Udo
701件の閲覧回数
kerryzhou
Hi @udoeb ,
   Thank you for your contribution.
   You are right!
  It is the SDK but, I will report to the SDK team directly, it will be fixed in the new version.
    Thanks again.
kerry
702件の閲覧回数
kerryzhou
Hi @udoeb ,
   You are right!
    Thanks again.
kerry
