I found an issue in CLOCK_GetPllFreq():
In case kCLOCK_PllArm the line:
postDiv = (1UL << (postDiv + 1UL));
does not handle POST_DIV_SEL=3 correctly. The code should be fixed as follows:
postDiv = (postDiv == 3) ? 1 : (1UL << (postDiv + 1UL));
See also register ARM_PLL_CTRL in the manual.
Udo
解決済! 解決策の投稿を見る。
Hi @udoeb ,
Thank you for your contribution.
You are right!
It is the SDK but, I will report to the SDK team directly, it will be fixed in the new version.
Thanks again.
kerry
Hi @udoeb ,
You are right!
Thanks again.
kerry
