Currently we are having difficulty in purchasing SDRAM IS42S16160J-6BLI(ISSI)
can you suggest some replaceable parts?
What are the conditions when choosing replacement parts.?
Sorry but I don't understand RAM well
For example, can I replace it with an AS4C16M16SA-7BCN (Alliance Memory) component?
I attached the datasheet.
Haryanl
Solved! Go to Solution.
Hi yuh ah,
I recommend you to check the SEMC chapter of the reference manual where you can see the limitations for SDRAM.
Felipe
Hi yuh ah,
Felipe
Hi Felipe
Thank for your support
I will consider it
