My program can't run after reset
469 次查看
LiangWuLW
My development board is from Positive Dot Atom,and it downloaded and ran fine at first.But I used the Erase function in MDK, which is under the Flash option, and the board could not run after reset .It can be debugged and downloaded, but it won't work if reset or powered back on
455 次查看
EdwinHz
Hi @LiangWuLW,
Could you please provide me with the part number, SDK version and IDE release you are currently using? Thanks in advance.
