HI
I need to use two ethernet interface and have them both operational. I haven't found any relevant examples in the SDK.
Thanks.
Solved! Go to Solution.
Hi @kevin198776 ,
Thanks for your interest in NXP MIMXRT series!
As you said, there is no dual Ethernet demo in the SDK at the moment, which makes it difficult for developers. But our colleagues have worked on a project (unofficially released) for RT106X based dual Ethernet. I don't know if this fully meets your needs, but for that matter, it's the only resource I can find at the moment. Thanks for your kind understanding in advance!
Gavin
For the i.MX RT 106x take a look at the uTasker project, which supports flexible networking solutions:
Multiple networks on multiple interfaces on
- single or dual Ethernet
- Wifi
- Tethered USB
https://www.utasker.com/index.html
https://www.utasker.com/docs/uTasker/uTaskerNetworking.pdf
https://www.utasker.com/docs/iMX/uTaskerV1.4_iMX.pdf
https://www.utasker.com/docs/uTasker/uTaskerRNDIS.pdf
https://www.utasker.com/docs/uTasker/uTaskerWIFI.pdf
Allowing complete project development,and i.MX RT simulation using VisualStudio (including TCP/IP stack on emulated i.MX RT in real-time).
Mark (uTasker project lead)
For our discounted i.MX and Kinetis production stock availability see https://www.utasker.com/Shop/semi.html
Hi @kevin198776 ,
Gavin
Hi @kevin198776 ,
Thanks for your feedback.
But as far as I know, there shouldn't be any new EVK design for RT106x. But there may be some third parties that are implementing dual network ports. This link: https://community.nxp.com/t5/i-MX-RT/RT1061-Dual-Ethernet-MDIO-Interface-Questions/td-p/1521883
Also, the RT117x has an EVK that supports dual network ports.
Gavin
