3.3V SD support on RT595
640 次查看
daisukeyoshinar
Hello.
I'm considering using i.MX RT595.
Is it possible for i.MX RT595 to access an SD that only supports 3.3V?
I understand that it is not supported by EVK.
I also found the following document.
https://www.nxp.com/docs/en/user-guide/IMXRT500HDG.pdf
P.41
Due to the removal of 3.3 V support on the high-speed pads, the SD card interface is no longer supported.
This considerably reduced the current leakage on VDD1V8. An erratum is issued to describe this further describe.
We are evaluating the use of using an external level shifter to enable this.
Where can I find the evaluation results when using an external level shifter?
Daisuke Yoshinari
601 次查看
_Leo_
Thank you so much for your interest in our products and for using our community.
This erratum is still being worked on, please wait for the next release of our Errata Report for a better description and workaround.
Please activate the alerts in the product page to stay informed when documentation is updated.
I thank you for your patience and understanding in advance.
Have a nice day!
602 次查看
_Leo_
Have a nice day!
586 次查看
daisukeyoshinar
Thank you for your reply.
I'm waiting for the documentation to be updated.
thank you.
Daisuke Yoshinari
