videocrop not working with imxvideoconvert_g2d on imx8mp Kirkstone
malik_cisse
Senior Contributor I
I am experiencing an issue when using cropping in gstreamer (linux kernel 5.15.60)
This pipeline works just fine:
gst-launch-1.0 v4l2src device=/dev/video1 ! video/x-raw,format=YUY2,width=1920,height=1080 ! videocrop top=0 left=0 right=0 bottom=0 ! imxvideoconvert_g2d ! video/x-raw, width=800, height=480 ! waylandsink
whereas this one will lead to a video with artifacts:
gst-launch-1.0 v4l2src device=/dev/video1 ! video/x-raw,format=YUY2,width=1920,height=1080 ! videocrop top=0 left=60 right=60 bottom=0 ! imxvideoconvert_g2d ! video/x-raw, width=800, height=480 ! waylandsink
The artifacts are as attached.
I did not have this issue when using earlier kernels (5.4.70). I conclude that this might be introduced in imxvideoconvert_g2d plugin recently.
It does not mater which cropping is set, it never works.
 Thank you for hints
M.Cisse
Bio_TICFSL
You should try the L5.15.52 BSP it works nicelly and you kernel version is official supported.
