Dear @Johnli ,
I am studying your article "i.MX8X_5.4.24_bootloader customization application", for uuu port you said:
I am confused why uuu usb port can be changed through uboot code modifying?
in the RM, seems the flow is running on ROM code, before u-boot code running?
and what does "active first " mean here? first register in the code, or first receive data on the port?
thank you very much!
Yes, you understanding it right. For the one is active means only one port can be used when download, usb2.0 OTG port or usb 3.0 port, it depends on your design.
