Dear all,
The posting before asked a question about device and u-boot. It seems that u-boot uses device tree, I also found the device tree file in the u-boot-imx directory. But in the release's porting guide, there is no mention about modifying device tree. Do I need to modify device tree file for release 2020.04-r0 u-boot release?
thank you,
Hai
Solved! Go to Solution.
U-boot Device Tree describes only modules that are needed for boot, just as an example I2C, UART, SPI, USB, you may modify it accordingly for your design.
Aldo.
Aldo.
