power supply for rtc
1,903 次查看
Dhvani
I am working on i.MX8m mini evk, I want to know the power supply for RTC. As per the document
@IMX8MMIEC.pdf  in SNVS mode, there are two power supplies VDD_SNVS_0P8 and NVCC_SNVS_1P8 that are remains on to give power to rtc. So which one of from these is the power for RTC.
Thank you
1,875 次查看
Dhvani
hi @riteshmpatel
Thank you for your response
1,883 次查看
riteshmpatel
Hi @Dhvani,
I hope you are doing well.
As mentioned in Table 67. i.MX 8M Mini 14 x 14 mm functional contact assignments in the datasheet, the power group of RTC is NVCC_SNVS_1P8.
Thanks & Regards,
Ritesh M Patel
