panel-lvds driver does not work anymore after upgrade to kernel 6.6
3,457件の閲覧回数
MicMoba
I upgrade my Linux kernel from 5.15.52 to 6.6. After upgrading my panel only shows a small stripe. I made no changes at the device tree. When I use the panel-simple driver instead of panel-lvds I got a working display. Does someone know about changes in the driver.
I use a iMX8MP and my panel is connected to LVDS1 interface.
dmesg shows a message but I can't identify the failure
dmesg | grep lvds
[ 0.077630] platform panel-lvds1: Fixed dependency cycle(s) with /ldb-display-controller/lvds-channel@1
[ 2.511277] imx8mp-ldb ldb-display-controller: Failed to create device link (0x180) with phy-lvds
[ 2.552129] imx8mp-ldb ldb-display-controller: Failed to create device link (0x180) with panel-lvds1
ラベル(3)
タグ(5)
6 返答(返信)
3,435件の閲覧回数
Bio_TICFSL
Have you checked the dtb? are they changed? which lvds device are you working on?
3,423件の閲覧回数
MicMoba
yes I checkd the dtb. I convert the dtb back to dts. The new one as the old one. I can't see any differences.
I use a DataModul 10,1“ TFT – WXGA – LVDS panel (TX26D207VM0AAA)
2,523件の閲覧回数
tw22
Failure occurs early during boot. This might indicate clocks problem. Check e. g. clock-names in node ldb read by drivers. What are you using? drm display-subsystem or frame buffers (mxc) ?
3,414件の閲覧回数
MicMoba
Here are my settings. Maybe you find a mistake
    backlight1: backlight1 {
        compatible = "pwm-backlight";
        pinctrl-names = "default";
        pinctrl-0 = <&pinctrl_lvds1>;
        default-brightness-level = <6>;
        pwms = <&pwm3 0 50000 0>;
        power-supply = <&reg_lvds1_reg_en>;
        enable-gpios = <&gpio2 20 GPIO_ACTIVE_LOW>;
        brightness-levels= <0 4 8 16 32 64 128 255>;
        status = "okay";
    panel_lvds: panel-lvds1 {
        compatible  = "panel-lvds";
        backlight   = <&backlight1>;
        width-mm = <218>;
        height-mm = <137>;
        data-mapping = "vesa-24";
        status = "okay";
        panel-timing {
            clock-frequency = <71000000>;
            hactive = <1280>;
            hfront-porch = <30>;
            hsync-len = <48>;
            hback-porch = <80>;
            vactive = <800>;
            vfront-porch = <3>;
            vsync-len = <6>;
            vback-porch = <14>;
        port {
            panel1_in: endpoint {
                remote-endpoint = <&lvds1_out>;
&lcdif2 {
  status = "okay";
/* LVDS1 */
&ldb {
    status = "okay";
    lvds-channel@1 {
        #address-cells = <1>;
	#size-cells = <0>;
        status = "okay";
        primary;
        port@1 {
            reg = <1>;
            lvds1_out: endpoint {
                remote-endpoint = <&panel1_in>;
&ldb_phy {
    status = "okay";
2,290件の閲覧回数
festevam
@MicMoba
This is an old thread, but I faced the same problem.
In my case, I had to pass the de-active = <1>; property to fix it.
909件の閲覧回数
brood
I have also been struggling with the same issue for over a week now, and adding this property ('de-active = <1>;') to the panel-timing definition in my device tree finally resolved the issue. My display works now, thanks for this! If I could give you more than 1 Kudo I would
%3CLINGO-SUB%20id%3D%22lingo-sub-1922948%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%206.6%20%E3%81%AB%E3%82%A2%E3%83%83%E3%83%97%E3%82%B0%E3%83%AC%E3%83%BC%E3%83%89%E3%81%97%E3%81%9F%E5%BE%8C%E3%80%81panel-lvds%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%8C%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%AA%E3%81%8F%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1922948%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%3CP%3ELinux%20%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%82%92%205.15.52%20%E3%81%8B%E3%82%89%206.6%20%E3%81%AB%E3%82%A2%E3%83%83%E3%83%97%E3%82%B0%E3%83%AC%E3%83%BC%E3%83%89%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%82%A2%E3%83%83%E3%83%97%E3%82%B0%E3%83%AC%E3%83%BC%E3%83%89%E5%BE%8C%E3%80%81%E3%83%91%E3%83%8D%E3%83%AB%E3%81%AB%E3%81%AF%E5%B0%8F%E3%81%95%E3%81%AA%E3%82%B9%E3%83%88%E3%83%A9%E3%82%A4%E3%83%97%E3%81%AE%E3%81%BF%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%84%E3%83%AA%E3%83%BC%E3%81%AB%E3%81%AF%E5%A4%89%E6%9B%B4%E3%82%92%E5%8A%A0%E3%81%88%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82panel-lvds%20%E3%81%AE%E4%BB%A3%E3%82%8F%E3%82%8A%E3%81%AB%20panel-simple%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%81%8C%E5%8B%95%E4%BD%9C%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%AE%E5%A4%89%E6%9B%B4%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E7%9F%A5%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E4%BA%BA%E3%81%AF%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%20iMX8MP%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E3%83%91%E3%83%8D%E3%83%AB%E3%81%AF%20LVDS1%20%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%81%AB%E3%82%B3%E3%83%8D%E3%82%AF%E3%83%86%E3%83%83%E3%83%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3Edmesg%E3%81%AB%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%AF%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%82%8BCAN%E3%80%81%E5%A4%B1%E6%95%97%E3%81%AE%E5%8E%9F%E5%9B%A0%E3%81%8C%E5%88%86%E3%81%8B%E3%82%89%E3%81%AA%E3%81%84%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3Edmesg%20%7C%20grep%20lvds%0A%5B%200.077630%5D%20platform%20panel-lvds1%3A%20Fixed%20dependency%20cycle(s)%20with%20%2Fldb-display-controller%2Flvds-channel%401%0A%5B%202.511277%5D%20imx8mp-ldb%20ldb-display-controller%3A%20Failed%20to%20create%20device%20link%20(0x180)%20with%20phy-lvds%0A%5B%202.552129%5D%20imx8mp-ldb%20ldb-display-controller%3A%20Failed%20to%20create%20device%20link%20(0x180)%20with%20panel-lvds1%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1922948%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX%208M%20%7C%20i.MX%208M%20%E3%83%9F%E3%83%8B%20%7C%20i.MX%208M%20%E3%83%8A%E3%83%8E%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3ELinux%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EYocto%20Project%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2146984%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20panel-lvds%20driver%20does%20not%20work%20anymore%20after%20upgrade%20to%20kernel%206.6%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2146984%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E7%A7%81%E3%82%82%201%20%E9%80%B1%E9%96%93%E4%BB%A5%E4%B8%8A%E5%90%8C%E3%81%98%E5%95%8F%E9%A1%8C%E3%81%AB%E6%82%A9%E3%81%BE%E3%81%95%E3%82%8C%E3%81%A6%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20%E3%83%84%E3%83%AA%E3%83%BC%E3%81%AE%E3%83%91%E3%83%8D%E3%83%AB%E3%82%BF%E3%82%A4%E3%83%9F%E3%83%B3%E3%82%B0%E5%AE%9A%E7%BE%A9%E3%81%AB%E3%81%93%E3%81%AE%E3%83%97%E3%83%AD%E3%83%91%E3%83%86%E3%82%A3%20('de-active%20%3D%20%26lt%3B1%26gt%3B%3B')%20%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%80%81%E3%82%88%E3%81%86%E3%82%84%E3%81%8F%E5%95%8F%E9%A1%8C%E3%81%8C%E8%A7%A3%E6%B1%BA%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%E3%81%8C%E5%8B%95%E4%BD%9C%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99!%E3%82%82%E3%81%971%E3%81%A4%E4%BB%A5%E4%B8%8A%E3%81%AEKudo%E3%82%92CAN%E3%81%AA%E3%82%89%20%3CLI-EMOJI%20id%3D%22lia_slightly-smiling-face%22%20title%3D%22%3Aslightly_smiling_face%3A%22%3E%3C%2FLI-EMOJI%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2039961%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20panel-lvds%20driver%20does%20not%20work%20anymore%20after%20upgrade%20to%20kernel%206.6%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2039961%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F24576%22%20target%3D%22_blank%22%3E%40MicMoba%3C%2FA%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%AF%E5%8F%A4%E3%81%84Thread%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E7%A7%81%E3%82%82%E5%90%8C%E3%81%98%E5%95%8F%E9%A1%8C%E3%81%AB%E7%9B%B4%E9%9D%A2%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E7%A7%81%E3%81%AECASE%E3%80%81%E3%81%93%E3%82%8C%E3%82%92%E4%BF%AE%E6%AD%A3%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%20de-active%20%3D%20%26lt%3B1%26gt%3B%3B%20%E3%83%97%E3%83%AD%E3%83%91%E3%83%86%E3%82%A3%E3%82%92%E6%B8%A1%E3%81%99%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2020199%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20panel-lvds%20driver%20does%20not%20work%20anymore%20after%20upgrade%20to%20kernel%206.6%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2020199%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%B5%B7%E5%8B%95%E4%B8%AD%E3%81%AB%E6%97%A9%E6%9C%9F%E3%81%AB%E9%9A%9C%E5%AE%B3%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%81%AE%E5%95%8F%E9%A1%8C%E3%82%92%E7%A4%BA%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%89%E3%82%8C%E3%81%9F%E3%83%8E%E3%83%BC%E3%83%89%20LDB%20%E5%86%85%E3%81%AE%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E5%90%8D%E3%81%AA%E3%81%A9%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E4%BD%95%E3%82%92%E4%BD%BF%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9Fdrm%20%E3%83%87%E3%82%A3%E3%82%B9%E3%83%97%E3%83%AC%E3%82%A4%20%E3%82%B5%E3%83%96%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%8B%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%20%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%83%BC%20(mxc)%20%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1923349%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20panel-lvds%20driver%20does%20not%20work%20anymore%20after%20upgrade%20to%20kernel%206.6%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1923349%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%8C%E7%A7%81%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%81%A7%E3%81%99%E3%80%82%E9%96%93%E9%81%95%E3%81%84%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%82%8B%E3%81%8B%E3%82%82%E3%81%97%E3%82%8C%E3%81%AA%E3%81%84%3C%2FP%3E%3CBR%20%2F%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3E%2F%20%7B%0A%20%20%20%20backlight1%3A%20backlight1%20%7B%0A%20%20%20%20%20%20%20%20compatible%20%3D%20%22pwm-backlight%22%3B%0A%20%20%20%20%20%20%20%20pinctrl-names%20%3D%20%22default%22%3B%0A%20%20%20%20%20%20%20%20pinctrl-0%20%3D%20%26lt%3B%26amp%3Bpinctrl_lvds1%26gt%3B%3B%0A%20%20%20%20%20%20%20%20default-brightness-level%20%3D%20%26lt%3B6%26gt%3B%3B%0A%20%20%20%20%20%20%20%20pwms%20%3D%20%26lt%3B%26amp%3Bpwm3%200%2050000%200%26gt%3B%3B%0A%20%20%20%20%20%20%20%20power-supply%20%3D%20%26lt%3B%26amp%3Breg_lvds1_reg_en%26gt%3B%3B%0A%20%20%20%20%20%20%20%20enable-gpios%20%3D%20%26lt%3B%26amp%3Bgpio2%2020%20GPIO_ACTIVE_LOW%26gt%3B%3B%0A%20%20%20%20%20%20%20%20brightness-levels%3D%20%26lt%3B0%204%208%2016%2032%2064%20128%20255%26gt%3B%3B%0A%20%20%20%20%20%20%20%20status%20%3D%20%22okay%22%3B%0A%20%20%20%20%7D%3B%0A%0A%20%20%20%20panel_lvds%3A%20panel-lvds1%20%7B%0A%20%20%20%20%20%20%20%20compatible%20%20%3D%20%22panel-lvds%22%3B%0A%20%20%20%20%20%20%20%20backlight%20%20%20%3D%20%26lt%3B%26amp%3Bbacklight1%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%0A%20%20%20%20%20%20%20%20width-mm%20%3D%20%26lt%3B218%26gt%3B%3B%0A%20%20%20%20%20%20%20%20height-mm%20%3D%20%26lt%3B137%26gt%3B%3B%0A%0A%20%20%20%20%20%20%20%20data-mapping%20%3D%20%22vesa-24%22%3B%0A%20%20%20%20%20%20%20%20status%20%3D%20%22okay%22%3B%0A%20%20%20%20%20%20%20%20%0A%20%20%20%20%20%20%20%20panel-timing%20%7B%0A%20%20%20%20%20%20%20%20%20%20%20%20clock-frequency%20%3D%20%26lt%3B71000000%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20hactive%20%3D%20%26lt%3B1280%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20hfront-porch%20%3D%20%26lt%3B30%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20hsync-len%20%3D%20%26lt%3B48%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20hback-porch%20%3D%20%26lt%3B80%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20vactive%20%3D%20%26lt%3B800%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20vfront-porch%20%3D%20%26lt%3B3%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20vsync-len%20%3D%20%26lt%3B6%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20vback-porch%20%3D%20%26lt%3B14%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%7D%3B%0A%20%20%20%20%20%20%20%20%0A%20%20%20%20%20%20%20%20port%20%7B%0A%20%20%20%20%20%20%20%20%20%20%20%20panel1_in%3A%20endpoint%20%7B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20remote-endpoint%20%3D%20%26lt%3B%26amp%3Blvds1_out%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%7D%3B%0A%20%20%20%20%20%20%20%20%7D%3B%0A%20%20%20%20%7D%3B%0A%7D%3B%0A%26amp%3Blcdif2%20%7B%0A%20%20status%20%3D%20%22okay%22%3B%0A%7D%3B%0A%2F*%20LVDS1%20*%2F%0A%26amp%3Bldb%20%7B%0A%20%20%20%20status%20%3D%20%22okay%22%3B%0A%0A%20%20%20%20lvds-channel%401%20%7B%0A%20%20%20%20%20%20%20%20%23address-cells%20%3D%20%26lt%3B1%26gt%3B%3B%0A%09%23size-cells%20%3D%20%26lt%3B0%26gt%3B%3B%20%20%20%20%20%20%20%20%0A%20%20%20%20%20%20%20%20status%20%3D%20%22okay%22%3B%0A%20%20%20%20%20%20%20%20primary%3B%0A%20%20%20%20%20%20%20%20port%401%20%7B%0A%20%20%20%20%20%20%20%20%20%20%20%20reg%20%3D%20%26lt%3B1%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20lvds1_out%3A%20endpoint%20%7B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20remote-endpoint%20%3D%20%26lt%3B%26amp%3Bpanel1_in%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%7D%3B%0A%20%20%20%20%20%20%20%20%7D%3B%0A%20%20%20%20%7D%3B%0A%7D%3B%0A%0A%26amp%3Bldb_phy%20%7B%0A%20%20%20%20status%20%3D%20%22okay%22%3B%0A%7D%3B%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1923328%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20panel-lvds%20driver%20does%20not%20work%20anymore%20after%20upgrade%20to%20kernel%206.6%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1923328%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%AF%E3%81%84%E3%80%81dtb%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82dtb%20%E3%82%92%20dts%20%E3%81%AB%E6%88%BB%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E6%96%B0%E3%81%97%E3%81%84%E3%82%82%E3%81%AE%E3%82%82%E5%8F%A4%E3%81%84%E3%82%82%E3%81%AE%E3%82%82%E3%80%82%E9%81%95%E3%81%84%E3%81%AFCAN%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AFDataModul%2010.1%E3%82%A4%E3%83%B3%E3%83%81TFT%20%E2%80%93%20WXGA%20%E2%80%93%20LVDS%E3%83%91%E3%83%8D%E3%83%AB%EF%BC%88TX26D207VM0AAA%EF%BC%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1923082%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20panel-lvds%20driver%20does%20not%20work%20anymore%20after%20upgrade%20to%20kernel%206.6%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1923082%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%0A%3CP%3Edtb%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8B%EF%BC%9F%E5%A4%89%E6%9B%B4%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%E3%81%A9%E3%81%AE%20LVDS%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E6%89%B1%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
