Dear Sir,
I read "i.MX 8M Dual/8M QuadLite/8M Quad Applications Processors Reference Manual",
Document Number: IMX8MDQLQRM (Rev. 0, 01/2018). But I can't find any register spec about USB-phy.
But in imx-linux "imx8mq_clocks.dtsi" I found there are registers at 0x382f0040.
Where can I found the definitions of USB-phy registers? Thanks.
usb3_phy1: phy@382f0040 {
compatible = "fsl,imx8mq-usb-phy";
#phy-cells = <1>;
reg = <0x0 0x382f0040 0x0 0x40>;
clocks = <&clk IMX8MQ_CLK_USB2_PHY_ROOT>;
clock-names = "usb_phy_root_clk";
assigned-clocks = <&clk IMX8MQ_CLK_USB_PHY_REF_SRC>;
assigned-clock-parents = <&clk IMX8MQ_SYS1_PLL_100M>;
assigned-clock-rates = <100000000>;
status = "disabled";
Hello, I need the PHY registers definition for IMX8M Nano but I cannot find them on the reference manual. Can somebody help please?
Hi Wang,
I have internally escalated your request, in order to verify if there are missing information on the i.MX8M Reference Manual.
I will post an update as soon as having news.
Best regards!
/Carlos
Hi Miles,
Sorry for the delayed response. Below you can find last update from AE team:
We have sent out request to design/document team to add USBPHY information into future RM.
So, could you please specify if does the customer need relative description urgently?
In case that yes, please create a Salesforce Case and let us know the number.
Hope this will be useful for you.
Best regards!
/Carlos
Hi Miles,
In such case, could you please create a Salesforce Case on where we could manage future interactions involving attachments?
You could take a look at the following link:
How to submit a new question for NXP Support
Best regards!
/Carlos
Hello Miles,
I have sent you a direct message where you could reply me with the numeric reference for your created Case.
Best regards!
/Carlos
Did this ever get resolved? We have the same questions about the USB PHY register descriptions, and the response we got back from NXP is that none exist?
Hi, I have the same need. Did you succeed to collect some info ?
OK, in fact reference manual Rev. 2, 08/2019 contains the USB controller + USB PHY registers descriptions so it's all good !
