in portrait mode, the performance is very slow. The maximum frame rate is only about 10 fps
Brady
The problem of frame loss after rotating the screen
Our project used IMX8MM development of Android9.0, and encountered a problem, when the screen was rotated, the frame dropped seriously.
Our analysis is as follows:
1. systrace->mytrace_normal.html before rotating the screen:
2. systrace->mytrace_dropframe.html after rotating the screen:
The main time-consuming is eglSwapBuffersWithDamageKHR function
Please help to check if there is a patch to fix this problem
Brady
@Zhiming_Liu
do i need to supply other information. Thanks.
Brady
@Zhiming_Liu Do I have any other imformation need to supply? Thanks very much.
Brady
Android platform version 9
Platform SDK version 28
Zhiming_Liu
我们的android9有详细的版本号,比如android9_1.0.0,android9_1.2.0....等等,你是哪一个版本
Zhiming_Liu
Hi @Brady
Which android version you are using?
Brady
Thanks, we are using Android 9.0.
Zhiming_Liu
Please tell me the detailed android version so that i can provide libegl.so file
Brady
@Zhiming_Liu
Hello, could you please help me. Thanks.
or do i need to supply some more information.
Zhiming_Liu
@Brady
Do you have NXP NDA ?This EGL library needs NDA.
Brady
@Zhiming_Liu
NDA #90230
Just update NDA Number.
Brady
@Zhiming_Liu
Yes,we have NDA.
Could you please check "Hansong(Nanjing)Technology LTD" at your side, and my mail is,
Brady.zheng@hansonggroup.com
you can also find us by.
Jelly.sha@hansonggroup.com
Jason.sun@hansonggroup.com
or we can send NDA by mail, Please help there.
Thanks again for your help.
Zhiming_Liu
@Brady
Have sent the email
Zhiming_Liu
@Brady
I will send it to your email next week.The library needs some time to generate.
Brady
@Zhiming_Liu
ok, well noted. Thanks again for you help.
Brady
@Zhiming_Liu
Thanks, we should have, i am checking internal team.
we already have products using IMX8MM run into mass production.
Brady
@Zhiming_Liu
Thanks and sorry for late reply.
please refer to below information:
DEFAULT_PLATFORM_VERSION := PPR1
PLATFORM_VERSION.PPR1 := 9
PLATFORM_SDK_VERSION := 28
hope there infor are what you want. Thanks again for your help.
Zhiming_Liu
Brady
I have replaced the corresponding .so file in the vendor directory and compiled the code, but there will still be frame drop problems, please confirm and reply as soon as possible
Brady
@Zhiming_Liu
Thanks, but we still have the problem, could you please suggest is there any consideration you have, and do we need to supply other information for you.
Brady
@Zhiming_Liu
Thanks, confirmed we used p9.0.0_2.3.0.
