The problem of frame loss after rotating the screen
Our project used IMX8MM development of Android9.0, and encountered a problem, when the screen was rotated, the frame dropped seriously.
Our analysis is as follows:
1. systrace->mytrace_normal.html before rotating the screen:
2. systrace->mytrace_dropframe.html after rotating the screen:
The main time-consuming is eglSwapBuffersWithDamageKHR function
Please help to check if there is a patch to fix this problem
@Zhiming_Liu Do I have any other imformation need to supply? Thanks very much.
Android platform version 9
Platform SDK version 28
我们的android9有详细的版本号,比如android9_1.0.0,android9_1.2.0....等等,你是哪一个版本
Thanks, we are using Android 9.0.
Please tell me the detailed android version so that i can provide libegl.so file
Do you have NXP NDA ?This EGL library needs NDA.
Yes,we have NDA.
Could you please check "Hansong(Nanjing)Technology LTD" at your side, and my mail is,
you can also find us by.
or we can send NDA by mail, Please help there.
Thanks again for your help.
I will send it to your email next week.The library needs some time to generate.
ok, well noted. Thanks again for you help.
Thanks, we should have, i am checking internal team.
we already have products using IMX8MM run into mass production.
Thanks and sorry for late reply.
please refer to below information:
DEFAULT_PLATFORM_VERSION := PPR1
PLATFORM_VERSION.PPR1 := 9
PLATFORM_SDK_VERSION := 28
hope there infor are what you want. Thanks again for your help.
Plaese go to this https://www.nxp.com.cn/design/software/embedded-software/i-mx-software/android-os-for-i-mx-applicati... to find your correct version
I have replaced the corresponding .so file in the vendor directory and compiled the code, but there will still be frame drop problems, please confirm and reply as soon as possible
Thanks, but we still have the problem, could you please suggest is there any consideration you have, and do we need to supply other information for you.
Thanks, confirmed we used p9.0.0_2.3.0.
