imx8mq android8.1 modified the init.rc,after make bootimage can not apply?
已解决
跳至解决方案
1,751 次查看
传策薛
Contributor V
Hi,community:
   I add something to the /device/fsl/evk_8mq/init.rc,  and then "make bootimage"(I can see the $OUT/root/init.freescale.rc is changed),   and "fast boot flash boot.img", but when the board up, I found  that the /init.freescale.rc  did not changed, How is that happened?
help me.
1 解答
1,586 次查看
diegoadrian
Unfortunately, I do not know if there will be a faster way. But everything points that not. I apologize for the inconveniences.
Diego.
在原帖中查看解决方案
4 回复数
1,586 次查看
diegoadrian
I apologize for the late answer
Let me verify with my board if this happens.
Furthermore, can you please try building the whole Android GUI again and not only the boot image?
Diego.
1,586 次查看
传策薛
Contributor V
Dear Diego~:
   Build the whole Android can  apply the changes of “init.rc”, but  if I can just "make bootimage" to apply the "init.rc", that will help my debugs a lot~~~,Can Android8.1 has some faster way to apply "init.rc"  without build the whole Android Source?
1,587 次查看
diegoadrian
Diego.
1,586 次查看
传策薛
Contributor V
Thank you same~
