imx8mp gstreamer issue:I want to set a video on fix position with fix size
3,352件の閲覧回数
MicMoba
Contributor V
I am not able to show a video with fix size on a fix position. Here is my GStreamer-pipeline:
gst-launch-1.0 imxcompositor_g2d name=comp sink_0::xpos=0 sink_0::ypos=0 sink_0::width=320 sink_0::height=240 ! waylandsink window-width=320 window-height=240 filesrc location=/home/moba/codesys/Videos/TestedByMW.mp4 ! qtdemux ! vpudec ! videoconvert ! comp.sink_0
 I call the same pipeline 4 times and the video always has another position on the screen. Look at the attached images.
On my device I use the wayland display server protocol.
My objective is to place a video with a fixed size to absolute corordinates.
E.g:
Size=320x240
xpos= 50
ypos=100
5 返答(返信)
2,713件の閲覧回数
ClaireT
I recently encountered an issue with Quicktime where I couldn't figure out how to split a video. After some digging, I found a fantastic solution that might help others facing the same challenge. I came across this comprehensive guide on the Movavi Learning Portal: https://www.movavi.com/learning-portal/best-free-mp4-editors.html. It not only explains how to split videos but also introduces some excellent free MP4 editors. I found it incredibly helpful and thought it might benefit the community here. Feel free to check it out and let me know if it solves your Quicktime video-splitting dilemma too! Happy editing!
3,334件の閲覧回数
joanxie
set xpos and ypos to position, like sink_0::xpos=500 sink_0::ypos=500
3,328件の閲覧回数
MicMoba
Contributor V
sink_0::xpos=500 sink_0::ypos=500 moves only the video inside the window which is defined with window-with and window-height at waylandsink.
It does not move the window itself
3,176件の閲覧回数
joanxie
waylandsink doesn't support window position, maybe you can try ivi-shell
3,053件の閲覧回数
MicMoba
Contributor V
I tried ivi-shell, but it seems the same problem.
1. The output Window is very very small
2. Every time I call for example a gstreamer the output window will appear at another position
3. I can not scale the window. Neither the size nor the position can be set.
