imx8mm wifi input password cannot connect, but you can connect to a router that does not require a p
1,006 次查看
yzg
Hi,nxp
wifi input password cannot connect, but you can connect to a router that does not require a password
844 次查看
brian14
Hi @yzg
Unfortunately, that WIFI module is unsupported for BSPs higher than 5.4.47.
I suggest you use this BSP or try a workaround described on the following link:
Enabling QCA9377 Wifi Driver for imx8mm-lpddr4-evk - NXP Community
I hope this information will be helpful.
Have a great day!
7 回复数
979 次查看
brian14
Hi @yzg
Could you please tell me your BSP version to review this issue?
949 次查看
yzg
kernel 5.15.71
924 次查看
brian14
Hi @yzg
I tried using the BSP version LF5.15.71_2.2.2 and WIFI is working fine using a network with password and network without password.
Are you trying using The Linux User's Guide connectivity section to properly set the WiFi?
i.MX Linux User's Guide (nxp.com)
890 次查看
yzg
Is wifi related to the configuration in uboot? I use LF_V202.04, ddr4 2g, 100% connection failure, but there are some small probability of uboot connection failure
867 次查看
brian14
Hi @yzg
I don't think the problem could be related to Uboot configuration.
Are you using a custom board?
If not, what is your EVK version?
I would like to identify the WIFI module.
856 次查看
yzg
Hi,nxp
WIFI module is qca9377
845 次查看
brian14
Hi @yzg
Have a great day!
