imx8mm EVK eMMC sync hung task (L5.4.3_200)
Khai
Hello everybody!
I have tested on imx8mm EVK board, with write-enabled mount option on eMMC (formated as EXT4), sync task may sometimes get stuck due to disk sleep. It seems that  sync task takes too long to complete IO operations. Please see the log message attached bellow.
This issue does not occur on micro SD cards with the same test.
Does anybody have the same problem?
Thanks and best regards,
Trinh Khai.
