I need to use the sound card on imx8mq and the connection mode is i2c and i2s.I2s has seven pins: MCLK, LRCK, SCLK, SDIN1, SDIN2, SDIN3, SDIN4
But no one knows how to change the SAI configuration.Do you only need to change DTS?Want answers or examples.Thank you very much!
Hi dhty2015
one can look at "pinctrl_sai1_pcm: sai1grp_pcm" dts example on
fsl-imx8mq-evk.dts\freescale\dts\boot\arm64\arch - linux-imx - i.MX Linux kernel
