imx7 : haw to enable rpmsg on imx7
683 次查看
marouen
Dear all,
I have been working with the Colibri IMX7D board, and I want to make use of the RPMSG module to communicate between the 2 cores (cortex m4 and cortex A7).
the RPMSG demos work with toradex images but can't run them in my custom image,
I have enabled  RPMSG drivers through defconfig file and enabled RPMSG through the status property in the devices trees with no result. I view the forums through the internet and I didn't find the solution, Would somebody please elaborate?
Thank you.
0 回复数
