Thank you so much for your information.
I'm working on imx8mm and trying to use the lt8912b driver for lt8912
My kernel version is 6.6.23
I copied your dts.txt settings to the imx8mm-evk.dts, and I have this error repeating below:
[ 4.321983] lt8912 1-0048: failed to find dsi host
[ 4.351954] lt8912 1-0048: failed to find dsi host
[ 4.381217] lt8912 1-0048: failed to find dsi host
[ 4.412626] lt8912 1-0048: failed to find dsi host
[ 4.442807] lt8912 1-0048: failed to find dsi host
Did you add your changes to the same imx8mm-evk.dts, or did you use different version?
