If you refer to schematic of the SPF-28616, it belongs to the Base Board, which is shared between the i.MX6UL and the i.MX6ULL. The CPU board is of the schematic SPF-28617.
Hope this will be useful for you. Best regards! /Carlos
Best regards!
/Carlos
Hi Carlos,
If you download EVK zip file from here:
MCIMX6ULL-EVK|i.MX6ULL Evaluation Kit|NXP
You will see that the schematic is named as MCIMX6UL and its CPU is MCIMX6G not MCIMX6Y.
The PDF file SPF-28617_C5 is exactly the same as in the MCIMX6UL zip content.
Could you please double check and share the right PDF file ?
Bardia
AE team confirmed that i.MX6ULL is exactly pin to pin compatible with i.MX6UL. That's why the same files are used for both of them.
Best regards!
/Carlos
Hi Carlos,
Thanks, you are right. They are similar.
I searched more in other communities and a guy told me that I should look for SPF-29364 !
Could you please ask AE team if it is correct and how it can be accessed ?
Bardia
I have searched on the Community and I didn’t find any other references to SPF-29364. Could you please provide more details?
Best regards!
/Carlos
