I wanted to know how fuse programming works on the iMX535 (using the "fuse" command in u-boot). Are my following assumptions correct:-
1. If fuse bit(s) are not blown the default value = 0
2. fuse bit is only blown once you program a value of 1 (and the configuration/fuse retains this value permanently)
I was unable to find this exact information in the ref manual / datasheet.
SZ
解決済! 解決策の投稿を見る。
Hi sherry
1. right
2. right
Hi sherry
1. right
2. right
