Dear team
The RM00284: EdgeLock Enclave Hardware Security Module API documentation does not provide specific examples of API usage. Could you provide guidance on how to securely import a KEK (Key Encryption Key), including any sample code?
If this key is wiped (all 128 fuse bits programmed to 1), ELE will use a Device Unique Key(DUK) as master key. This DUK is known by ELE only. The Generate KEY Blob request must be used to wrap the blobs.
Harvey
