i.MX8QM with edp panel
792 次查看
lizboxy
Hi,Sir:
How do we driver the EDP panel on i.MX8QM @L4.14.98?
The Datasheet of panel is in attached,pls advise,TKs!
726 次查看
joanxie
depends on how your HW design, you need change the dtb file according to your HW design, you can refer to the current dts file then set as you need
https://source.codeaurora.org/external/imx/linux-imx/tree/arch/arm64/boot/dts/freescale/fsl-imx8qm-m...
