i.MX8MP with ISL79987 Schematic Review
561 次查看
Wobaffet
Senior Contributor I
We'll be using ISL79987 for the 4 analog NTSC cameras as decoder and our connection with the MPU can be seen on the attached images. Can you verify the connection? Thank you in advance!
Gencay Akyuz
538 次查看
riteshmpatel
Hi @Wobaffet,
I hope you are doing well.
The 2-lane MIPI-CSI connections seem okay.
Thanks & Regards,
Ritesh M Patel
539 次查看
riteshmpatel
Hi @Wobaffet,
Thanks & Regards,
Ritesh M Patel
