i.MX6Q PCIe : cannot read from 0x0100_0000~0x01FF_BFFF
1,294件の閲覧回数
masamiyasui
In i.MX6 Quad, could you tell me the conditions that make the following areas accessible?
  0x0100_0000~0x01FF_BFFF  16,368KB  PCIe
Currently, read access to this area causes an abnormal state (freeze).
(Non-Linux system)
I understand that this area is used for outbound transfer and MSI interrupt.
The register area below can be read and written normally.
  0x01FF_C000~0x01FF_FFFF  16KB  PCIe registers
The current setting is described below.
- PageTable of the corresponding area is defined collectively with other peripherals as a device.
    // 0x01000000 - 0x02bfffff : I/O Access #2
- The PCIe peripheral clock is set as follows.
    CCM_ANALOG_PLL_ENET
      ENABEL=1
      ENABLE_100M=1
      ENABLE_125M=1
      * These are set after confirming that LOCK == 1 after setting POWERDOWN = 0.
    CCM_CCGR4
      CG0=0b11
    IOMUXC_GPR1
      REF_SSP_EN=1
Please let me know if there are other necessary information.
i.mx6q pcie‌#pci express#imx6
ラベル(3)
5 返答(返信)
975件の閲覧回数
masamiyasui
Problem solved.
Thank you for your cooperation.
Under the following conditions, the read access of the corresponding area succeed.
-  Set i.MX 6 to EndPoint Device
-  Link up
-  Set 0x01000000 to the local address of the outbound region (PCIE_PL_iATURLBA)
-  Set the PCIe address published by Root Complex to the target address  of the outbound region (PCIE_PL_iATURLTA)
975件の閲覧回数
masamiyasui
Sorry for lack of explanation.
The problem I am facing is that it is not a readout via PCI express, it can not be read out merely directly.
For example, freeze with the following code.
val = *((uint32_t *)(0x01000000));     /* this is bare metal system */
975件の閲覧回数
igorpadykov
for bare-metal please check SDK examples on
Github SDK
https://github.com/backenklee/swp-report/tree/master/iMX6_Platform_SDK
975件の閲覧回数
igorpadykov
975件の閲覧回数
igorpadykov
Hi Masami
please check some restrictions described on
PCIe BAR length limit
