enable spi (mars board )
768 次查看
hamzadardour
Hi everyone,
I would like enable spi for user space, because I don't find spix.x in /dev.
I enter the command ( modprobe spidev ) and it works ( verefied with lsmod ).
I found in some forums that I have to change the code of the  file ( board-mx6q_marsboard.c )  to add spi for user space, but I don't know the gpio that I can use for the Cselect , this is the  part of the code that could enable the spi ,
( the code between starts is what I had added )
could you help me please ,
/* start
#define MX6Q_MARSBOARD_ECSPI1_CS0  IMX_GPIO_NR(2, 30)
#define MX6Q_MARSBOARD_ECSPI2_CS0  IMX_GPIO_NR(2, 27)
#define MX6Q_MARSBOARD_ECSPI3_CS0  IMX_GPIO_NR(**, **)   ( I don't know gpios number
static int mx6q_marsboard_spi0_cs[] = {
        MX6Q_MARSBOARD_ECSPI1_CS0,
static const struct spi_imx_master mx6q_marsboard_spi0_data __initconst = {
        .chipselect     = mx6q_marsboard_spi0_cs,
        .num_chipselect = ARRAY_SIZE(mx6q_marsboard_spi0_cs),
static int mx6q_marsboard_spi1_cs[] = {
        MX6Q_MARSBOARD_ECSPI2_CS0,
static const struct spi_imx_master mx6q_marsboard_spi1_data __initconst = {
        .chipselect     = mx6q_marsboard_spi1_cs,
        .num_chipselect = ARRAY_SIZE(mx6q_marsboard_spi1_cs),
//********************************** my code 1
static int mx6q_marsboard_spi2_cs[] = {
        MX6Q_MARSBOARD_ECSPI3_CS0,
static const struct spi_imx_master mx6q_marsboard_spi2_data __initconst = {
        .chipselect     = mx6q_marsboard_spi2_cs,
        .num_chipselect = ARRAY_SIZE(mx6q_marsboard_spi2_cs),
//***************************** end of my code 1
static struct spi_board_info imx6_marsboard_spi_devices[] __initdata = {
#if defined(CONFIG_MTD_M25P80)
        .modalias = "m25p80",
        .max_speed_hz = 20000000, /* max spi clock (SCK) speed in HZ */
        .bus_num = 0,
        .chip_select = 0,
        .platform_data = &imx6_marsboard__spi_flash_data,
#endif
                .modalias = "ads7846",
                .bus_num = 1,
                .chip_select = 0,
                .max_speed_hz = 1500000,
                .irq = gpio_to_irq(MX6Q_MARSBOARD_RES_TCH_INT),
                .platform_data = &ads7846_config,
//***************** my code 2
        .modalias = "spidev",
        .max_speed_hz = 48000000, //48 Mbps
        .bus_num = 2,
        .chip_select = 0,
        .mode = 0,
//****************** end of my code 2
*/ end
0 回复数
