eboot_ivt.sb doesn't support Nand flash
RichardXiao
MFGtool update Wince into Nand flash failed;
boot from SD card, eboot can't find Nand flash;
I download wince image from freescale website;
so, result is that eboot doesn't support nand flash ??
RichardXiao
Table 7. BSP Known Issues/Limitations
Limitation/Issue :If NAND Flash was programmed by other OS or program,
WinCE BSP may have problem read/write NAND as normal.
Workaround:Perform a low-level NAND format in EBOOT.
