Zipping the application image and placing it in flash
Vidya_1203
We are trying to port an application from MCF5282 to MXRT117 mcu. In the previous project the application image was zipped and placed in flash, unzipped using a third party library called 'zlib' and copied to sdram. We need to implement a similar procedure for MXRT117. What is the best method we can follow? Is there any tool/library we can use to make the above process much simpler?
Bio_TICFSL
They are different architecture and different core version,zlib is supported too in RT but you need to compile first the project on ARM core.
Vidya_1203
Is there any example for RT series?
