YOCTO project: How to build modify source code for driver.
3,425件の閲覧回数
hemalgandhi
Hello ,
We have downloaded the yocto BSP for L3.5 version and build it according to Freescale_user_guide.pdf file. It has created the Build directory and under that Linux driver code resides. i want to change the driver for IPU and GPU. What is the procedure after modifying the  Driver code.
Hemal
ラベル(3)
2,289件の閲覧回数
LeonardoSandova
Specialist I
If your driver will be built-in, then you can follow this doc
i.MX Yocto Project: How can I (quickly) modify the kernel and test it?
