Hi All,
We have ported driver using NL80211 interface in Android 6 platform. Wi-Fi is up and connection established with Access point[Open/Secured].
After when we try to disconnect the connected Access point in android GUI, wpa_supplicant is crashing by signal 11.
Error Log:
action=android.net.conn.INET_CONDITION_ACTION
01-01 00:02:01.651 540 581 E WifiConfigStore: rewrite network history for "Redmi"WPA_PSK
01-01 00:02:02.267 1273 1273 D wpa_supplicant: EAPOL: startWhen --> 0
01-01 00:02:02.267 1273 1273 D wpa_supplicant: EAPOL: disable timer tick
01-01 00:02:03.060 238 533 W audio_hw_primary: do_out_standby... -1243289856
01-01 00:02:03.385 1273 1273 D wpa_supplicant: wlan0: Control interface command 'IFNAME=wlan0 SIGNAL_POLL'
01-01 00:02:03.385 1273 1273 D wpa_supplicant: CTRL-DEBUG: ctrl_sock-sendto: sock=10 sndbuf=163840 outq=0 send_len=49
01-01 00:02:03.386 540 583 D ConnectivityService: updateNetworkScore for NetworkAgentInfo [WIFI () - 100] to 48
01-01 00:02:06.390 1273 1273 D wpa_supplicant: wlan0: Control interface command 'IFNAME=wlan0 SIGNAL_POLL'
01-01 00:02:06.390 1273 1273 D wpa_supplicant: CTRL-DEBUG: ctrl_sock-sendto: sock=10 sndbuf=163840 outq=0 send_len=49
01-01 00:02:06.392 540 583 D ConnectivityService: updateNetworkScore for NetworkAgentInfo [WIFI () - 100] to 46
01-01 00:02:08.949 540 583 D ConnectivityService: handlePromptUnvalidated 100
01-01 00:02:09.396 1273 1273 D wpa_supplicant: wlan0: Control interface command 'IFNAME=wlan0 SIGNAL_POLL'
01-01 00:02:09.397 1273 1273 D wpa_supplicant: CTRL-DEBUG: ctrl_sock-sendto: sock=10 sndbuf=163840 outq=0 send_len=49
01-01 00:02:09.398 540 583 D ConnectivityService: updateNetworkScore for NetworkAgentInfo [WIFI () - 100] to 44
01-01 00:02:11.264 1273 1273 D wpa_supplicant: wlan0: Control interface command 'IFNAME=wlan0 SCAN TYPE=ONLY'
01-01 00:02:11.264 1273 1273 D wpa_supplicant: wlan0: Setting scan request: 0.000000 sec
01-01 00:02:11.264 1273 1273 D wpa_supplicant: CTRL-DEBUG: ctrl_sock-sendto: sock=10 sndbuf=163840 outq=0 send_len=3
01-01 00:02:11.265 1273 1273 D wpa_supplicant: wlan0: Starting AP scan for wildcard SSID
01-01 00:02:11.265 1273 1273 D wpa_supplicant: wlan0: Add radio work 'scan'@0xb6bd90f0
01-01 00:02:11.265 1273 1273 D wpa_supplicant: wlan0: First radio work item in the queue - schedule start immediately
01-01 00:02:11.265 1273 1273 D wpa_supplicant: wlan0: Starting radio work 'scan'@0xb6bd90f0 after 0.000154 second wait
01-01 00:02:11.265 1273 1273 D wpa_supplicant: wlan0: nl80211: scan request
01-01 00:02:11.265 1273 1273 D wpa_supplicant: nl80211: Scan SSID - hexdump(len=0): [NULL]
01-01 00:02:11.265 1273 1273 D wpa_supplicant: nl80211: Scan extra IEs - hexdump(len=6): 7f 04 00 00 0a 02
01-01 00:02:11.266 1273 1273 D wpa_supplicant: Scan requested (ret=0) - scan timeout 30 seconds
01-01 00:02:11.266 1273 1273 D wpa_supplicant: RTM_NEWLINK: ifi_index=5 ifname=wlan0 wext ifi_family=0 ifi_flags=0x11043 ([UP][RUNNING][LOWE)
01-01 00:02:11.266 1273 1273 D wpa_supplicant: nl80211: Event message available
01-01 00:02:11.266 1273 1273 D wpa_supplicant: nl80211: Drv Event 33 (NL80211_CMD_TRIGGER_SCAN) received for wlan0
01-01 00:02:11.266 1273 1273 D wpa_supplicant: wlan0: nl80211: Scan trigger
01-01 00:02:11.266 1273 1273 D wpa_supplicant: wlan0: Event SCAN_STARTED (47) received
01-01 00:02:11.266 1273 1273 D wpa_supplicant: wlan0: Own scan request started a scan in 0.000576 seconds
01-01 00:02:11.266 1273 1273 D wpa_supplicant: CTRL-DEBUG: ctrl_sock-sendmsg: sock=10 sndbuf=163840 outq=448 send_len=24
01-01 00:02:11.267 540 1274 E WifiHW : Received the following from the supplicant: <3>CTRL-EVENT-SCAN-STARTED
01-01 00:02:11.267 1273 1273 D wpa_supplicant: CTRL_IFACE monitor sent successfully to /data/misc/wifi/sockets/wpa_ctrl_540-6\x00
01-01 00:02:11.267 1273 1273 D wpa_supplicant: nl80211: Event message available
01-01 00:02:11.267 1273 1273 D wpa_supplicant: nl80211: Drv Event 34 (NL80211_CMD_NEW_SCAN_RESULTS) received for wlan0
01-01 00:02:11.267 1273 1273 D wpa_supplicant: wlan0: nl80211: New scan results available
01-01 00:02:11.267 1273 1273 D wpa_supplicant: nl80211: Scan probed for SSID ''
01-01 00:02:11.268 1273 1273 D wpa_supplicant: nl80211: Scan included frequencies: 2412 2417 2422 2427 2432 2437 2442 2447 2452 2457 2462 244
01-01 00:02:11.268 1273 1273 D wpa_supplicant: wlan0: Event SCAN_RESULTS (3) received
01-01 00:02:11.268 1273 1273 D wpa_supplicant: wlan0: Scan completed in 0.001481 seconds
01-01 00:02:11.268 1273 1273 D wpa_supplicant: nl80211: Associated on 2462 MHz
01-01 00:02:11.268 1273 1273 D wpa_supplicant: nl80211: Associated with 8c:be:be:3b:25:7b
01-01 00:02:11.268 1273 1273 D wpa_supplicant: nl80211: Received scan results (1 BSSes)
01-01 00:02:11.268 1273 1273 D wpa_supplicant: nl80211: Scan results indicate BSS status with 8c:be:be:3b:25:7b as associated
01-01 00:02:11.268 1273 1273 D wpa_supplicant: wlan0: BSS: Start scan result update 6
01-01 00:02:11.268 1273 1273 D wpa_supplicant: BSS: last_scan_res_used=1/32
01-01 00:02:11.269 1273 1273 D wpa_supplicant: wlan0: New scan results available (own=1 ext=0)
01-01 00:02:11.269 1273 1273 D wpa_supplicant: CTRL-DEBUG: ctrl_sock-sendmsg: sock=10 sndbuf=163840 outq=0 send_len=24
01-01 00:02:11.269 540 1274 E WifiHW : Received the following from the supplicant: <3>CTRL-EVENT-SCAN-RESULTS
01-01 00:02:11.269 1273 1273 D wpa_supplicant: CTRL_IFACE monitor sent successfully to /data/misc/wifi/sockets/wpa_ctrl_540-6\x00
01-01 00:02:11.269 1273 1273 D wpa_supplicant: WPS: AP[0] c4:e9:84:88:9a:e2 type=0 tries=0 last_attempt=-1 sec ago blacklist=0
01-01 00:02:11.269 1273 1273 D wpa_supplicant: WPS: AP[1] b4:75:0e:cc:50:79 type=0 tries=0 last_attempt=-1 sec ago blacklist=0
01-01 00:02:11.270 1273 1273 D wpa_supplicant: wlan0: Radio work 'scan'@0xb6bd90f0 done in 0.004528 seconds
01-01 00:02:11.270 1273 1273 D wpa_supplicant: wlan0: Selecting BSS from priority group 1
01-01 00:02:11.270 1273 1273 D wpa_supplicant: wlan0: 0: 8c:be:be:3b:25:7b ssid='Redmi' wpa_ie_len=0 rsn_ie_len=20 caps=0x431 level=77
01-01 00:02:11.270 1273 1273 D wpa_supplicant: wlan0: selected based on RSN IE
01-01 00:02:11.270 1273 1273 D wpa_supplicant: wlan0: selected BSS 8c:be:be:3b:25:7b ssid='Redmi'
01-01 00:02:11.272 1273 1273 D wpa_supplicant: wlan0: Control interface command 'IFNAME=wlan0 BSS RANGE=0- MASK=0x29d87'
01-01 00:02:11.272 1273 1273 D wpa_supplicant: WPS: Unknown Vendor Extension (Vendor ID 9442)
01-01 00:02:11.276 1273 1273 D wpa_supplicant: CTRL-DEBUG: ctrl_sock-sendto: sock=10 sndbuf=163840 outq=0 send_len=3965
01-01 00:02:11.284 1273 1273 D wpa_supplicant: wlan0: Control interface command 'IFNAME=wlan0 STATUS-NO_EVENTS'
01-01 00:02:11.285 1273 1273 D wpa_supplicant: EAPOL: EAP Session-Id not available
01-01 00:02:11.285 1273 1273 D wpa_supplicant: CTRL-DEBUG: ctrl_sock-sendto: sock=10 sndbuf=163840 outq=0 send_len=233
01-01 00:02:12.400 1273 1273 D wpa_supplicant: wlan0: Control interface command 'IFNAME=wlan0 SIGNAL_POLL'
01-01 00:02:12.400 1273 1273 D wpa_supplicant: CTRL-DEBUG: ctrl_sock-sendto: sock=10 sndbuf=163840 outq=0 send_len=49
01-01 00:02:12.401 540 583 D ConnectivityService: updateNetworkScore for NetworkAgentInfo [WIFI () - 100] to 42
01-01 00:02:14.881 238 533 W audio_hw_primary: out_set_parameters routing=1024, ret 0, out -1243289856
01-01 00:02:14.891 238 533 I audio_hw_primary: start_output_stream_primary... -1243289856, device 1024
01-01 00:02:14.893 238 533 W audio_hw_primary: card 1, port 0 device 0x400
01-01 00:02:14.893 238 533 W audio_hw_primary: rate 44100, channel 2 period_size 0x300
01-01 00:02:15.166 232 1291 E BufferQueueProducer: [Redmi] dequeueBuffer: can't dequeue multiple buffers without setting the buffer count
01-01 00:02:15.403 1273 1273 D wpa_supplicant: wlan0: Control interface command 'IFNAME=wlan0 SIGNAL_POLL'
01-01 00:02:15.404 1273 1273 D wpa_supplicant: CTRL-DEBUG: ctrl_sock-sendto: sock=10 sndbuf=163840 outq=0 send_len=49
01-01 00:02:15.406 540 583 D ConnectivityService: updateNetworkScore for NetworkAgentInfo [WIFI () - 100] to 40
01-01 00:02:15.663 540 1301 D NetlinkSocketObserver: NeighborEvent{elapsedMs=138500, 192.168.43.1, [8CBEBE3B257B], RTM_NEWNEIGH, NUD_STALE}
01-01 00:02:17.972 238 533 W audio_hw_primary: do_out_standby... -1243289856
01-01 00:02:18.059 238 533 W audio_hw_primary: out_set_parameters routing=1024, ret 0, out -1243289856
01-01 00:02:18.068 238 533 I audio_hw_primary: start_output_stream_primary... -1243289856, device 1024
01-01 00:02:18.069 238 533 W audio_hw_primary: card 1, port 0 device 0x400
01-01 00:02:18.069 238 533 W audio_hw_primary: rate 44100, channel 2 period_size 0x300
01-01 00:02:18.073 540 581 E WifiConfigStore: removeNetwork 0 key="Redmi"WPA_PSK config.id=0 crc=1087246119
01-01 00:02:18.079 1273 1273 D wpa_supplicant: wlan0: Control interface command 'IFNAME=wlan0 REMOVE_NETWORK 0'
01-01 00:02:18.079 1273 1273 D wpa_supplicant: CTRL_IFACE: REMOVE_NETWORK id=0
01-01 00:02:18.079 1273 1273 D wpa_supplicant: wlan0: Request to deauthenticate - bssid=8c:be:be:3b:25:7b pending_bssid=00:00:00:00:00:00 reD
01-01 00:02:18.079 1273 1273 D wpa_supplicant: TDLS: Tear down peers
01-01 00:02:18.079 1273 1273 D wpa_supplicant: wpa_driver_nl80211_disconnect(reason_code=3)
01-01 00:02:18.079 1273 1273 D wpa_supplicant: wlan0: Event DEAUTH (12) received
01-01 00:02:18.079 1273 1273 D wpa_supplicant: wlan0: Deauthentication notification
01-01 00:02:18.080 1273 1273 D wpa_supplicant: wlan0: * reason 3 (locally generated)
01-01 00:02:18.080 1273 1273 D wpa_supplicant: Deauthentication frame IE(s) - hexdump(len=0): [NULL]
01-01 00:02:18.080 1273 1273 I wpa_supplicant: wlan0: CTRL-EVENT-DISCONNECTED bssid=8c:be:be:3b:25:7b reason=3 locally_generated=1
01-01 00:02:18.080 1273 1273 D wpa_supplicant: CTRL-DEBUG: ctrl_sock-sendmsg: sock=10 sndbuf=163840 outq=0 send_len=76
01-01 00:02:18.080 1273 1273 D wpa_supplicant: CTRL_IFACE monitor sent successfully to /data/misc/wifi/sockets/wpa_ctrl_540-6\x00
01-01 00:02:18.080 1273 1273 D wpa_supplicant: wlan0: Auto connect disabled: do not try to re-connect
01-01 00:02:18.080 1273 1273 D wpa_supplicant: wlan0: Ignore connection failure due to local request to disconnect
01-01 00:02:18.080 1273 1273 D wpa_supplicant: TDLS: Remove peers on disassociation
01-01 00:02:18.080 1273 1273 D wpa_supplicant: wlan0: WPA: Clear old PMK and PTK
01-01 00:02:18.080 1273 1273 D wpa_supplicant: wlan0: Disconnect event - remove keys
01-01 00:02:18.080 1273 1273 D wpa_supplicant: wpa_driver_nl80211_set_key: ifindex=5 (wlan0) alg=0 addr=0x0 key_idx=0 set_tx=0 seq_len=0 key0
01-01 00:02:18.080 540 1274 E WifiHW : Received the following from the supplicant: <3>CTRL-EVENT-DISCONNECTED bssid=8c:be:be:3b:25:7b reas1
01-01 00:02:18.080 1273 1273 D wpa_supplicant: wpa_driver_nl80211_set_key: ifindex=5 (wlan0) alg=0 addr=0x0 key_idx=1 set_tx=0 seq_len=0 key0
01-01 00:02:18.080 1273 1273 D wpa_supplicant: wpa_driver_nl80211_set_key: ifindex=5 (wlan0) alg=0 addr=0xb6bf50b8 key_idx=0 set_tx=0 seq_le0
01-01 00:02:18.080 1273 1273 D wpa_supplicant: addr=8c:be:be:3b:25:7b
01-01 00:02:18.080 1273 1273 D wpa_supplicant: wlan0: State: COMPLETED -> DISCONNECTED
01-01 00:02:18.081 1273 1273 D wpa_supplicant: nl80211: Set wlan0 operstate 1->0 (DORMANT)
01-01 00:02:18.081 1273 1273 D wpa_supplicant: netlink: Operstate: ifindex=5 linkmode=-1 (no change), operstate=5 (IF_OPER_DORMANT)
01-01 00:02:18.081 1273 1273 D wpa_supplicant: CTRL-DEBUG: ctrl_sock-sendmsg: sock=10 sndbuf=163840 outq=0 send_len=71
01-01 00:02:18.081 1273 1273 D wpa_supplicant: CTRL_IFACE monitor sent successfully to /data/misc/wifi/sockets/wpa_ctrl_540-6\x00
01-01 00:02:18.081 1273 1273 D wpa_supplicant: EAPOL: External notification - portEnabled=0
01-01 00:02:18.081 540 1274 E WifiHW : Received the following from the supplicant: <3>CTRL-EVENT-STATE-CHANGE id=0 state=0 BSSID=8c:be:be:i
01-01 00:02:18.081 1273 1273 D wpa_supplicant: EAPOL: SUPP_PAE entering state DISCONNECTED
01-01 00:02:18.081 1273 1273 D wpa_supplicant: EAPOL: Supplicant port status: Unauthorized
01-01 00:02:18.081 1273 1273 D wpa_supplicant: nl80211: Skip set_supp_port(unauthorized) while not associated
01-01 00:02:18.081 1273 1273 D wpa_supplicant: EAPOL: SUPP_BE entering state INITIALIZE
01-01 00:02:18.081 1273 1273 D wpa_supplicant: EAPOL: External notification - portValid=0
01-01 00:02:18.081 1273 1273 D wpa_supplicant: EAPOL: External notification - EAP success=0
01-01 00:02:18.081 1273 1273 D wpa_supplicant: wlan0: State: DISCONNECTED -> DISCONNECTED
01-01 00:02:18.081 1273 1273 D wpa_supplicant: nl80211: Set wlan0 operstate 0->0 (DORMANT)
01-01 00:02:18.081 1273 1273 D wpa_supplicant: CTRL-DEBUG: ctrl_sock-sendto: sock=10 sndbuf=163840 outq=0 send_len=3
01-01 00:02:18.081 1273 1273 D wpa_supplicant: RTM_NEWLINK: ifi_index=5 ifname=wlan0 operstate=5 linkmode=1 ifi_family=0 ifi_flags=0x11003 ()
01-01 00:02:18.082 1273 1273 D wpa_supplicant: wlan0: Control interface command 'IFNAME=wlan0 SAVE_CONFIG'
01-01 00:02:18.082 1273 1273 D wpa_supplicant: Writing configuration file '/data/misc/wifi/wpa_supplicant.conf.tmp'
01-01 00:02:18.090 238 533 D AudioFlinger: mixer(0xb4200000) throttle end: throttle time(8)
01-01 00:02:18.140 1273 1273 D wpa_supplicant: Configuration file '/data/misc/wifi/wpa_supplicant.conf' written successfully
01-01 00:02:18.140 1273 1273 D wpa_supplicant: CTRL_IFACE: SAVE_CONFIG - Configuration updated
01-01 00:02:18.140 1273 1273 D wpa_supplicant: CTRL-DEBUG: ctrl_sock-sendto: sock=10 sndbuf=163840 outq=0 send_len=3
01-01 00:02:18.140 1273 1273 D wpa_supplicant: RTM_NEWLINK: ifi_index=5 ifname=wlan0 wext ifi_family=0 ifi_flags=0x11003 ([UP][LOWER_UP])
01-01 00:02:18.141 1273 1273 D wpa_supplicant: nl80211: Event message available
01-01 00:02:18.141 1273 1273 D wpa_supplicant: nl80211: Drv Event 48 (NL80211_CMD_DISCONNECT) received for wlan0
--------- beginning of crash
01-01 00:02:18.141 1273 1273 F libc : Fatal signal 11 (SIGSEGV), code 1, fault addr 0x4 in tid 1273 (wpa_supplicant)
01-01 00:02:18.145 540 581 D WifiNative-HAL: stopRssiMonitoring, cmdId 0
01-01 00:02:18.147 1063 1208 D OpenGLRenderer: endAllStagingAnimators on 0x91c92180 (RippleDrawable) with handle 0xb3b3fcf0
01-01 00:02:18.242 236 236 F DEBUG : *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** ***
01-01 00:02:18.243 236 236 F DEBUG : Build fingerprint: 'Freescale/sabresd_6dq/sabresd_6dq:6.0.1/2.1.0-ga-rc2/20160715:user/release-keys'
01-01 00:02:18.243 236 236 F DEBUG : Revision: '0'
01-01 00:02:18.243 236 236 F DEBUG : ABI: 'arm'
01-01 00:02:18.243 236 236 F DEBUG : pid: 1273, tid: 1273, name: wpa_supplicant >>> /system/bin/wpa_supplicant <<<
01-01 00:02:18.243 236 236 F DEBUG : signal 11 (SIGSEGV), code 1 (SEGV_MAPERR), fault addr 0x4
01-01 00:02:18.244 540 606 W NativeCrashListener: Couldn't find ProcessRecord for pid 1273
01-01 00:02:18.249 236 236 F DEBUG : r0 00000004 r1 80000000 r2 00000000 r3 00000000
01-01 00:02:18.249 236 236 E DEBUG : AM write failed: Broken pipe
01-01 00:02:18.249 236 236 F DEBUG : r4 b6bcb144 r5 b6bfa280 r6 b6bcf0e0 r7 00000000
01-01 00:02:18.249 236 236 F DEBUG : r8 b6bcf0f8 r9 7f705a1c sl b6bcb130 fp b6b82000
01-01 00:02:18.249 236 236 F DEBUG : ip b6e2ac98 sp bef23048 lr b6e227c9 pc b6e227c8 cpsr 00010030
01-01 00:02:18.286 236 236 F DEBUG :
01-01 00:02:18.286 236 236 F DEBUG : backtrace:
01-01 00:02:18.286 236 236 F DEBUG : #00 pc 0000a7c8 /system/lib/libnl.so (nla_get_u16+5)
01-01 00:02:18.287 236 236 F DEBUG : #01 pc 000a7ec1 /system/bin/wpa_supplicant
01-01 00:02:18.287 236 236 F DEBUG : #02 pc 00007b67 /system/lib/libnl.so (nl_recvmsgs+650)
01-01 00:02:18.287 236 236 F DEBUG : #03 pc 0009be4d /system/bin/wpa_supplicant
01-01 00:02:18.287 236 236 F DEBUG : #04 pc 000152fd /system/bin/wpa_supplicant
01-01 00:02:18.287 236 236 F DEBUG : #05 pc 00015967 /system/bin/wpa_supplicant
01-01 00:02:18.287 236 236 F DEBUG : #06 pc 00091e2b /system/bin/wpa_supplicant
01-01 00:02:18.287 236 236 F DEBUG : #07 pc 0000df2d /system/bin/wpa_supplicant
01-01 00:02:18.287 236 236 F DEBUG : #08 pc 00017365 /system/lib/libc.so (__libc_init+44)
01-01 00:02:18.288 236 236 F DEBUG : #09 pc 0000dfd8 /system/bin/wpa_supplicant
01-01 00:02:18.347 236 236 F DEBUG :
01-01 00:02:18.347 236 236 F DEBUG : Tombstone written to: /data/tombstones/tombstone_02
01-01 00:02:18.348 540 556 I BootReceiver: Copying /data/tombstones/tombstone_02 to DropBox (SYSTEM_TOMBSTONE)
01-01 00:02:21.149 238 533 W audio_hw_primary: do_out_standby... -1243289856
01-01 00:02:28.156 540 581 D WifiHW : 'IFNAME=wlan0 SET ps 1' command timed out.
01-01 00:02:28.158 235 523 D CommandListener: Clearing all IP addresses on wlan0
01-01 00:02:28.158 540 1302 D DhcpClient: Clearing IP address
01-01 00:02:28.162 540 1301 D NetlinkSocketObserver: NeighborEvent{elapsedMs=151000, 192.168.43.1, [8CBEBE3B257B], RTM_DELNEIGH, NUD_STALE}
01-01 00:02:28.173 235 523 D CommandListener: Setting iface cfg
01-01 00:02:28.183 540 583 D ConnectivityService: NetworkAgentInfo [WIFI () - 100] EVENT_NETWORK_INFO_CHANGED, going from CONNECTED to DISD
01-01 00:02:28.183 540 583 D ConnectivityService: NetworkAgentInfo [WIFI () - 100] got DISCONNECTED, was satisfying 2
01-01 00:02:28.185 540 581 D IpReachabilityMonitor: clear: iface{wlan0/5}, v{4}, ntable=[]
01-01 00:02:28.186 540 581 D WifiStateMachine: WifiStateMachine: Leaving Connected state
01-01 00:02:28.186 540 581 D IpReachabilityMonitor: clear: iface{wlan0/5}, v{5}, ntable=[]
01-01 00:02:28.192 540 581 D WifiNetworkAgent: NetworkAgent: NetworkAgent channel lost
01-01 00:02:28.198 540 583 D ConnectivityService: notifyType LOST for NetworkAgentInfo [WIFI () - 100]
01-01 00:02:28.212 540 1303 D DhcpClient: Receive thread stopped
01-01 00:02:28.268 235 523 V IdletimerController: runCmd(/system/bin/ip6tables -w -t raw -D idletimer_raw_PREROUTING -i wlan0 -j IDLETIMER0
01-01 00:02:28.334 235 523 V IdletimerController: runCmd(/system/bin/ip6tables -w -t mangle -D idletimer_mangle_POSTROUTING -o wlan0 -j ID0
01-01 00:02:28.338 540 583 D CSLegacyTypeTracker: Sending DISCONNECTED broadcast for type 1 NetworkAgentInfo [WIFI () - 100] isDefaultNetwe
01-01 00:02:28.339 540 583 D ConnectivityService: sendStickyBroadcast: action=android.net.conn.CONNECTIVITY_CHANGE
01-01 00:02:28.348 540 557 D Tethering: MasterInitialState.processMessage what=3
01-01 00:02:28.496 235 523 E Netd : netlink response contains error (No such file or directory)
01-01 00:02:28.499 540 583 E ConnectivityService: EVENT_NETWORK_INFO_CHANGED from unknown NetworkAgent
We didnot change anything in wpa supplicant,eventhough its getting crashed.
Could you please suggestion idea to fix this crash?
Raj.
Hi Thanaraj
this can be debugged using AN4553 Using Open Source Debugging Tools for Linux on i.MX Processors
http://www.nxp.com/assets/documents/data/en/application-notes/AN4553.pdf
note, nxp has Professional Services helping to port drivers
http://www.nxp.com/support/nxp-professional-services:PROFESSIONAL-SERVICE
