I have an Imx8 Mini EVK board running a custom Yocto OS. To my knowledge this board has a built-in wifi module (correct my if I'm wrong) so I've been attempting to enable wifi on this Yocto OS but couldn't find a solution for that. A dtb in the boot partition of Yocto which seems to be adding wifi support, has been tested as well but no lock.
I appreciate if anyone could give me a hint on how to handle this?
Thanks in advance.
If you are using the latest version of BSP it works,
