What is the purpose of TSENSOR?
1,248 次查看
adevries
Contributor V
On the 8M Mini processor, there are two pins I'm curious about, TSENSOR_TEST_OUT and TSENSOR_RES_EXT. What is the purpose of these pins? Do they need to be connected to anything? The datasheet, reference manual, and hardware design guide don't really talk about them.
标记 (2)
1,100 次查看
Bio_TICFSL
Hello adevries,
These pins are factory used only so TSENSOR_TEST_OUT leave floating and TSENSOR_RES_EXT connect over 100k to the GND.
1,100 次查看
eagan
Can you please add this to the documentation? I was unable to find it in any of the available i.MX 8M Mini docs.
1,101 次查看
Bio_TICFSL
Hello adevries,
