Unused pin connection for uSDHC data pin
1,300 次查看
ko-hey
Senior Contributor II
Hi all
I have a question about SDx_DATAx pin settings in i.MX6DL.
I plan to use SD card for boot.
SD card only use 4 bit. So I use only SDx_DATA0 to SDx_DATA3.
Does NXP have any recommendation for unsued pin connection ?
Also please let me know the register settings for unused pin.
Ko-hey
标签 (2)
4 回复数
1,200 次查看
Yuri
  Unused SDx_DATA[4-7] may be configured as GPIO, input, pulled up.
Note, this is default, Out of Reset state.
Yuri
1,200 次查看
ko-hey
Hi Yuri
Thank you for quick reply.
I understand it set as default.
How about pin connection ?
Do you recommend the pin connect to GND ? Or can I it to float ?
Ko-hey
1,199 次查看
Yuri
yes, the pins should be left floating.
~Yuri.
1,200 次查看
ko-hey
Hi Yuri
Thank you for your support.
I understand.
Ko-hey
