The detail fo IO DRV in MMPF0100.
805件の閲覧回数
satoshishimoda
Senior Contributor I
Hi community,
I have a question about MMPF0100 datasheet.
Please see Table 138, it shows IO DRV register in address 0x90, but there is no description about this register.
Would you let me know the detail, especially RESETBMCU_DRV?
Actually, I want to judge whether I can use RESETBMCU_DRV bit to control RESTBMCU singnal assert/deassert manually.
Satoshi Shimoda
タグ(1)
606件の閲覧回数
Yuri
  Basically, in Extended Page 2, most of these registers are used in TEST mode,
and may be marked as reserved. The RESETBMCU_DRV is just for tweaking internal
MOSFET drive parameters, not for asserting / deasserting ; RESETBMCU can't be controlled
manually.
Yuri
607件の閲覧回数
Yuri
manually.
Yuri
