I was play mp4 file, then a period of time found that there was no reaction to the system.This phenomenon is the probability of occurrence that need to play video a long time . I will upload the log . Can you give some advice?
Thanks.
Original Attachment has been moved to: systen_hang_up_paly_mp4.log.zip
this is kernel error, also android is based on linux.
~igor
Hi ferdinand
seems you are using L3.0.35 with gpu lib 4.6.9, this is very old,
suggest to upgrade at least to L3.0.101_4.1.1 as it fixed many gpu bugs:
Board Support Packages (38)
i.MX 6Quad, i.MX 6Dual, i.MX 6DualLite, i.MX 6Solo and i.MX 6Sololite
Linux BSP Source Code Files (REV L3.0.101_4.1.1.)
