System Controller Firmware - Build Environment
664 次查看
Danilo3
Hello everybody,
I need to customize the SCFW on i.MX8 QuadMax MEK for AAOS 13.0.0_1.1.0, so I downloaded the SCFW porting kit, release Linux LF5.15.71_2.2.0 (as indicated in the "Android Auto User's Guide 13-0-0").
Such porting kit comes with a sc_fw_port.pdf file which claims that the toolchain for compiling the SCFW is the GNU Arm Embedded Toolchain: 8-2018-q4-major December 20, 2018.
On the other hand, I see from the above-mentioned User's Guide that the version of "6-2017-q2-update June 28, 2017" is recommended, as it is verified.
Which one should I choose to avoid any issue?
Thank you
630 次查看
Danilo3
Hello @Chavira
based on your feedback, I will go for version "6-2017-q2-update" as document "Android User's Guide Rev. 13.0.0_1.1.0" is the latest one.
Thank you.
Regards.
636 次查看
Chavira
Hi @Danilo3
Thank you for contacting NXP Support!
I recommend following the latest document, all of our documentation is tested before the release.
If you have any problem using the tools you can out your issues in the community or a private case.
 https://www.nxp.com/support/support:SUPPORTHOME
631 次查看
Danilo3
Hello @Chavira
Thank you.
Regards.
