Schematics of SABRE-SDP
1,560 次查看
kapilkumar
what is the significance of keeping dot on resistor and capacitor in schematics ?
for e.g.,
Kapil Kumar
标签 (3)
7 回复数
1,422 次查看
Yuri
  many parts have pin number 1, often marked as dot on package.
Yuri.
1,422 次查看
kapilkumar
Hi Yuri
Good. Finally, i came to conclusion through your help and other sources is that this kind of symbol representation is only for the probing purpose by the PCB designer/Layout Engineer. Am I correct ? Pl, find an attachment. Pl, correct me if i am wrong ??
Kapil Kumar.
1,422 次查看
Yuri
Yes, Your idea is quite reasonable.
~Yuri.
1,422 次查看
Yuri
  it is just  CAD marking for the first pin.
Yuri
1,422 次查看
kapilkumar
Hi Yuri
As per my limited knowledge, resistor does not have pin no 1 or pin no 2 , either way we can connect. Right ?
1,422 次查看
Yuri
Yes, a resistor  in itself is symmetrical - it has no special pin numbering, but CAD may apply
such approach (to have marked pins) for compatibility with other parts.
Yuri.
1,422 次查看
kapilkumar
Hi Yuri
can you explain little bit more, what do you mean by compatibility with other parts ..?? if possible , pleas, explain it through some examples.
Kapil Kumar.
