Schematics of SABRE-SDP
kapilkumar
what is the significance of keeping dot on resistor and capacitor in schematics ?
for e.g.,
Kapil Kumar
Labels (3)
Yuri
  many parts have pin number 1, often marked as dot on package.
Yuri.
kapilkumar
Hi Yuri
Good. Finally, i came to conclusion through your help and other sources is that this kind of symbol representation is only for the probing purpose by the PCB designer/Layout Engineer. Am I correct ? Pl, find an attachment. Pl, correct me if i am wrong ??
Kapil Kumar.
Yuri
Yes, Your idea is quite reasonable.
~Yuri.
Yuri
  it is just  CAD marking for the first pin.
Yuri
kapilkumar
Hi Yuri
As per my limited knowledge, resistor does not have pin no 1 or pin no 2 , either way we can connect. Right ?
Yuri
Yes, a resistor  in itself is symmetrical - it has no special pin numbering, but CAD may apply
such approach (to have marked pins) for compatibility with other parts.
Yuri.
kapilkumar
Hi Yuri
can you explain little bit more, what do you mean by compatibility with other parts ..?? if possible , pleas, explain it through some examples.
Kapil Kumar.
